Gearshift in neutral or foward - Page 2 - SailNet Community
post #11 of 23 Old 07-07-2008
jjablonowski's Avatar
The black could be the wax (sometimes green, sometimes black) embedded in the stuffing-box packing. If overheated, it could ooze out with the dripping water.
jjablonowski is offline
post #12 of 23 Old 08-01-2008
Partially hydrated Member
Question Gearshift in neutral or reverse
So what is the consensus?
With an Atomic A-4, should you leave the gearshift in neutral or reverse?
Or doesn't it make a difference?
Thanks.
S/V Doodles
C&C 27
sanjuan2R is offline
post #13 of 23 Old 08-01-2008
Capnblu's Avatar
Put it in gear, as a spinning propeller will create as much drag as a solid diameter of the prop. Counterintuitive, but true. Better yet get yourself a quality folding prop.
Capnblu is offline
post #14 of 23 Old 08-01-2008
Originally Posted by chucklesR View Post
Engine oil should not get to the transmission,
Quite the contrary in this case. On an Atomic-4 the "transmission" (more correctly called a "reversing gear" on an A-4) is more-or-less integral with the engine and gets its lubrication from the engines lubrication system.
and past the stuffing box (not on a working engine.
Shouldn't even get to the stuffing box. With an A-4, there's an output flange on the back of the reversing gear. The prop shaft flange is coupled to that with four bolts. Obviously one should never see oil past the reversing gear case. (The foregoing assumes direct drive. I know not how V-drives are arranged.)
wchevron,
You should not be getting oil in the bilge from leaving your shifter in neutral while sailing. You may tend to get a small amount of oily residue in your engine space's bilge area, if from nothing else than blow-by. (All engines have some of that, and the original A-4s do not have a PCV [positive crankcase ventilationi] system to fully re-cycle crankcase blow-by). But that should result in no more than a slight oily sheen atop your water in the bilge from time-to-time. And when I say "slight," I do mean slight. As in: You have to look for it.
There are products out there you can place in your bilge that will soak up the oil and not the water. The most effective of these might be AbTech's Bilge Skimmer, based on their Smart Sponge technology. I have not found a place to buy that particular product and it's unclear to me whether it's re-usable. The other products claim they're re-usable.
(How the heck does one thoroughly clean an engine space on a sailboat, anyway? It's not as if one can climb in there with a power-washer. Least-wise not on a Pearson 30. Formula 409 and a boat-load of paper towels? )
I recommend you carefully check your engine space for oil leaks. Get a nice, bright flashlight. For example: When I recently checked our reversing gear adjustment, I found that somebody, at some point, had failed to replace its case cover's gasket and that was resulting in a small amount of oil seeping out from under it. Wasn't enough to amount to an appreciable amount of oil in the bilge, but still: It's bad form .
As for having that much water in your bilge after a few hours of your prop shaft turning while under sail: Sounds to me like your packing gland may need attention.
We put our shifter in reverse while under sail. But be careful: You probably have no neutral switch to prevent you from inadvertently starting the engine whilst in gear.
Jim
SEMIJim is offline
post #15 of 23 Old 08-01-2008
Special Delivery
speciald's Avatar
Send a message via Skype™ to speciald
Depends on the transmission; hydraulic or not. If hydraulic - should be in neutral, if mechanical - should be in reverse. Check your documentation. If you have a feathering prop, run up revs, shut down motor, then shift to reverse, shaft should not spin.
speciald is offline
post #16 of 23 Old 08-01-2008
It's common to put the transmission in reverse if you have a reduction gear...you don't. Just leave it in gear (assuming you're motoring forward) when you turn off the ignition. Oil does indeed lubricate the transmission on a A-4.
Neutral is not a good idea.
Howard Keiper
Sea Quest
Berkeley
thekeip is offline
post #17 of 23 Old 08-01-2008
My guess ????, which is what we are all doing, is that the question and the issue are not related.
First, unless the manufacturer of the transmission says to keep it in gear, put it in reverse. One, less drag. Two, why bother with the noise when you are sailing?
Now to the oil in the water guess. You stated in your follow up that you thought that the water was coming down the mast. Fix that. You also stated that you finally got a good sail in today? My guess is that if the boat is new to you, that you or the previous owner did a nice job of cleaning up the bilge before or after the sale. Now you get water down the mast and in the bilge, then you go sailing. Up, down, sideways, having the time of your life...right? The water, hopefully from the mast, is sloshing around in the bilge and getting under the engine where it did not get really clean in the prior cleaning. The water mixes with the oil and you have oily water in the bilge.
If my WAG is correct, you need to find out where the water is coming from and if there is a leak on the engine that has not shown up as yet. Don'g panic, there is always some blow by. You just want to make sure that it is not significant, which can be as easy as checking the oil before and after every sail...which should be done before every sail anyway. Wish I was religious about it....I am not.
Go sailing!
tommyt is offline
post #18 of 23 Old 08-01-2008
It is quite difficult to put and keep the transmission in reverse in the 1st place. Putting it into reverse and expecting to keep it there is not likely. Forward, in this transmission, is the only practical way to avoid undue wear.
Howard Keiper
thekeip is offline
post #19 of 23 Old 08-02-2008
Freesail99's Avatar
If you have an older Volvo Penta, your sailing with the engine in reverse.
S/V Scheherazade
Freesail99 is offline
post #20 of 23 Old 08-02-2008
Do not let the transmission spin when you are sailing.
Put the gearbox into reverse to stop it spinning.
A gearbox that is not spinning does not need lubrication.
Rockter is offline
Shorepower and Reverse Polarity oft Gear & Maintenance 31 07-15-2016 01:47 PM
HIgh RPM in neutral Philip Littman Pacific Seacraft 13 02-14-2007 08:46 AM
Outboard won''t stay in neutral HuntersMoon22 Gear & Maintenance 0 06-19-2005 05:38 PM
Sailing in gear or in neutral? palacegrand General Discussion (sailing related) 10 12-26-2004 04:15 AM
Transmission Engages while in neutral...? kmeeks Gear & Maintenance 1 02-18-2004 10:56 AM
