Gearshift in neutral or foward - Page 3 - SailNet Community
post #21 of 23 Old 08-02-2008
Westerbeke says neutral.
sander06 is offline
post #22 of 23 Old 08-02-2008
Don't let the prop spin though.
It'll drive you nuts listening to it scuffing along.
Rockter is offline
post #23 of 23 Old 08-02-2008
Originally Posted by thekeip View Post
It is quite difficult to put and keep the transmission in reverse in the 1st place. Putting it into reverse and expecting to keep it there is not likely. Forward, in this transmission, is the only practical way to avoid undue wear.
Admittedly, with an A-4 reversing gear, forward is more positive, because of the detent in the forcing cone--which is not present in reverse. We've experienced no problem putting ours in reverse and having it stay there throughout the sail, however. (We remove & store the shift lever during sail. Otherwise it's just sitting down there waiting to snag lines or get bumped into neutral .)
Jim
SEMIJim is offline
Shorepower and Reverse Polarity oft Gear & Maintenance 31 07-15-2016 01:47 PM
HIgh RPM in neutral Philip Littman Pacific Seacraft 13 02-14-2007 08:46 AM
Outboard won''t stay in neutral HuntersMoon22 Gear & Maintenance 0 06-19-2005 05:38 PM
Sailing in gear or in neutral? palacegrand General Discussion (sailing related) 10 12-26-2004 04:15 AM
Transmission Engages while in neutral...? kmeeks Gear & Maintenance 1 02-18-2004 10:56 AM
