Markers for Anchor Rode - Page 2 - SailNet Community
post #11 of 20 Old 07-07-2008
T37Chef's Avatar
I find it fun to count the links as they pan out, 1,2,3,4...100, 101, 102...and so on, while multiplying by the link size every other millisecond.
Shawn
T37Chef is online now
post #12 of 20 Old 07-07-2008
purveyor of mischief
sanctuarysam's Avatar
T37,
boy, we need to get you a hobby...
By three methods we may learn wisdom: first, by reflection, which is noblest,second is by imitation, which is easiest,third is by experience, which is the bitterest.
Sam
Sanctuary, Sabre 30 mkIII
sanctuarysam is offline
post #13 of 20 Old 07-07-2008
that's just his OCD manifesting itself.
sailingdog is offline
post #14 of 20 Old 07-08-2008
Omatako's Avatar
Marking chain is best done with the small plastic markers that insert into the chain links.
Hey Dog, have you actually used these, given the recommendation?
I have been thinking of using them but have had several people tell me thay don't really last as one would think. I have tried painting the chain but that wears off quite quickly. Have also tried cable ties but the windlass has those for lunch.
For three strand rope I splice in coloured twine and that lasts well but the chain has me beat.
Andre
Omatako is offline
post #15 of 20 Old 07-08-2008
Yes, I have used them and found that the good ones stay in place and last a fairly decent amount of time—far longer than the makeshift ones.
post #16 of 20 Old 07-08-2008
chucklesR's Avatar
Mark the length the actual distance from the anchor, anything else just makes it harder than it needs to be.
For chain, use paint.
I favor a band a color (red, white, blue, repeat) every ten feet instead of numbers. Laying out rode when anchoring isn't a precise science, if you need 70 feet to make it 7:1 then putting out 80 will not suddenly make your anchor fail to hold.
chucklesR is offline
post #17 of 20 Old 07-08-2008
moderate?
camaraderie's Avatar
For Chain...use paint. An easy way to do it is to lay out chain on the dock. in 1/2 the lengths you wish to mark and then double it back on itself. (Example: If you want to mark every 30 feet then lay out 15 feet and double back to the beginning making a 30ft. run). Do this with all the chain and all the multiples of 30 feet are at one end. Lay paper or cardboard boxes on the dock in advance and then just spray this end with Krylon or similar in a visible light color easily seen in the dark. Let dry and then shuffle the chain around a bit to expose undone areas. Repeat as necessary and you are done. I like marking the chain every 30 feet as that gives me a 6:1 ratio for every 5 foot increment in depth. I also put a "warning" paint job near the end of my rode so that I don't let it all out and stress the bulkhead attachment point. The warning needs to be placed 10 feet or so before the point where rode will be when it is fully extended at the windlass to give you time to react.
I find this cheap and easy to maintain. Most often all that is needed is to touch up the 30-60-90-120 ft. links as I rarely anchor in more than 20 ft. here in the east and these are the only links that see any wear except in unusual circumstances. I don't really understand the need to mark any more frequently since you don't need exactly a specific ratio and it is easy to judge or let out a few more feet than absolutely necessary by formula.
camaraderie is offline
post #18 of 20 Old 07-08-2008
Best Looking MALE Mod
Cruisingdad's Avatar
The only thing I have to add is that I have found by marking in different lengths, it is easier to see at night. Long lines 50', short lines 25. Thus, one long is 50, one long and a short is 75, two longs and a short is 125. They are different colors but hard to see at night. Not as big a deal if they fade, either. I do have to touch up periodically though.
- CD
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #19 of 20 Old 07-08-2008
I don't discuss my member
zz4gta's Avatar
Sailmaker's wipping at every 10', it took a little while, but I had some free time infront of the TV and it looks nice. I don't have the chain marking problem, as all the chain goes over the side everytime (very little chain).
Merit 25 # 764 "Audrey"
zz4gta is offline
post #20 of 20 Old 07-08-2008
TomKeffer's Avatar
For marking chain, I weave about 8" of 1/4" polypropylene rope through the links. It goes through the wildcat smoothly and is easy to see in dim light.
-tk
TomKeffer is offline
A Cautionary Note About Markers PBzeer General Discussion (sailing related) 6 02-10-2008 01:34 PM
shot markers captjohn360 Gear & Maintenance 11 01-26-2007 12:56 PM
Brass Pelican Chart Markers? Cap'nJeff Gear & Maintenance 2 06-27-2006 08:14 AM
Cruising the ICW, Part Two Sue & Larry Cruising Articles 0 02-05-2002 07:00 PM
