Old 07-01-2002
CISCOJOE is on a distinguished road
aluminum water tank
my aluminum water tank has developed an unpleasant taste and odor. i would appreciate suggestions for solving this problem. i can''t add bleach that''s going to make it worse. thanks in advance for your reply.
Old 07-11-2002
MGauthier is on a distinguished road
aluminum water tank
Ok Joe here i go i have not been sailing but have been reading everything i can get my hands on, one of the things i read said to stay away from aluminum tankage for the reason you mentioned and also due to corrosion problems, i would replace the tank. If i find the water tank in my just purchased Coronado 25 is aluminum it will come out. sorry i could not give you a quick fix.
Old 07-11-2002
MaryBeth is on a distinguished road
aluminum water tank
Sorry, maybe playing Devil''s advocate, but why would you buy a boat without knowing what in the hell is in the boat? I.E. "If I find the fresh water tank in my just purchased ....". If you buy a boat, know what''s on it. geez!!
Old 07-11-2002
bullseye is on a distinguished road
aluminum water tank
that was a bit harsh MaryBeth,i would still buy a vessel i really liked if i hadnt checked the water tank,id look at the important things first & leave the trivial(easily fixed/personalised)things till later if i had time,if your not an expert you can easily miss or forget things too,especially trivial things.
what are the walls made of in your house?
what timber is used in your flooring?
do you have 2 or 3 phase power?
catch my drift..
anyway just chatting for chattings sake
cya
Old 07-15-2002
gnorbury is on a distinguished road
aluminum water tank
Are you sure its the tank causing the odour problem?
IMHO the most likely source is your plumbing. I had to rip out all my old "clear" flexible hose because it''d turned black from fungal growth and made the water taste awful.
Graham
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
water ballast musolmar Boat Review and Purchase Forum 8 09-26-2004 04:50 PM
removing orig water tank zeilfanaat Gear & Maintenance 6 04-12-2004 06:26 AM
fresh water tank, tastes like ****! nauticalrich Gear & Maintenance 6 05-24-2002 04:17 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 05:59 PM
