07-08-2008
If you're leading the running rigging aft, you can often get away without any outhaul block and tackle system, since you'll have a winch at the cockpit to tension the outhaul line. That's how mine is setup now. Maintaining the blocks in the boom can be a royal PITA.
BTW, Faster's diagram is showing two fiddle blocks, one with a becket and one without, and not four separate blocks.
And it helps a lot to use a relatively low stretch line. StaSetX is an excellent choice for this purpose, since it is lower stretch and higher strength than regular polyester double braid, but relatively low cost. T-900 would be an even better choice, since it is even lower stretch and lighter too...but more expensive.
