07-10-2008
Originally Posted by jbondy
Sorry for the slight hijack!
chucklesR - Is your screacher (on its furler) always hoisted? Or do you haul it up on a halyard when you want to use it? If always hoisted, does it have sacrificial cloth on its leech and foot? I'm interested in something like that.
TIA
I am guessing that Chuckle's Screacher has a UV protective laminate called Tedlar added to the sail. While not quite as good as a Sunbrella UV-protective sacrificial strip, it does a fairly decent job while adding minimal weight to the sail. I have a screacher on my boat, and our sails are made by the same loft, since our boats are made by the same company. Be aware that most of the wire-luff furlers for headsails, like the screachers Chuckles and I have on our boats are designed to only furl the sails, not reef them.
Originally Posted by EO32
While on the topic.
I have a drifter (That's what the label says) which looks and feels like a light weight asymmetrical "spinnaker". The PO must have gotten it before he put on the rolling furler.
I was thinking about getting some "beaded loops" that I could rape around the rolled genoa and hank on to those.
Anybody tried that?
What you're thinking of are called parrel beads, and they're often used to attach the tack around a furled headsail. The ATN Tacker is much the same idea, using a fabric sleeve instead of the beads. It works fairly well. The Tacker is probably going to do less damage to the furled headsail, since it spreads the forces out far more evenly.
