07-11-2008
Steering Loss Continued... Corrosion Q
Hi all, finally got down to the Sundance to take a look at the steering to see what failed last week. It turns out that one of the anchors for the cables that attach to the rudder shaft failed, apparently from corrosion. The Edson helm uses a cast aluminum wheel that mounts to the rudder post. The control cables wrap around this wheel and terminate in molded "lugs", which have holes drilled into them and which the cable ends thread into. One of these "lugs" broke off, leaving me with no steering. I spoke with someone at Edson and they were helpful. A new wheel will cost about $250, not too bad. I cannot remove the old one in one piece, so I am going to try to salvage it by installing SS eyebolts on either side of the lug. The threaded cable end will still be able to attach in the same spot. I am not too sure of durability, but it will be easy to monitor. If it doesn't work, I am only out about $8 in SS parts. That brings me to my big question, how do you free up corroded parts? The rudder shaft looks like SS and the rudder wheel is aluminum. 27 years later, the parts do not want to part with each other. Is there a good spray that frees up parts like this?
Thanks for any help on this.
montenido
Odyssey, '79 CSY 44 Cutter
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
