07-11-2008
Working from the top down helps ensure a good repair, since gravity is working for you and helping hold the new core against the old inner laminate and the new laminate against the core, reducing the chances of large voids occuring. When working from the bottom up, you're far more likely to get large voids as the core material sags and pulls away from the outer laminate skin slightly.
As for Mango's avatar... it's obvious he's working from the bottom up.
