07-11-2008
Senior Mumble
Retaining clip in cockpit
When sailing the other night, we heard the sound of a metal piece hitting the cockpit floor. Not good, the idea of metal boat parts falling around us! Anyway, what we found were 3 pieces of what looks like a retaining clip, the spring kind that sits in a groove around a shaft, about 1" in diameter. This started a scramble to find what was about to fall apart. The only place we could find near where the part fell was the steering pedestal. It looks to be the snap ring from the wheel shaft where it exits the pedestal, but when we look at the shaft, it appears there is already a clip there. On the Edson site
( http://www.edsonmarine.com/support/P...eringGuide.pdf),
where they list the part (snap ring A-660), there is a 2 in parentheses. Does anyone know if this means there are supposed to be two of them there? Alternatively, it might be that there is one on the inside and one on the outside of the pedestal. If so, it would have been the outside one that broke since it fell in the cockpit. In either case, I hope we are not in imminent danger of the thing falling apart while we await a new part. If there are two on the outside, we probably are OK for a while. If there are not, and it looks like there already is one there, then I'm at a loss as to what happened. Does anyone have any insight on this?
We just had a Raymarine Wheel Pilot installed alomng with a new pedestal guard, so work was done in that area.
TIA
