Loud Squeal - Page 2 - SailNet Community
post #11 of 15 Old 07-13-2008
Disconnect the final drive coupling to stop the shaft turning. Check for squeal then.
Rockter is offline
post #12 of 15 Old 07-13-2008
Boat ownership transfer has nothing to do with it. What did the warranty actually say?
Rockter is offline
post #13 of 15 Old 07-13-2008 Thread Starter
Crazy Woman Boat Driver
Melrna's Avatar
Location: Heading south down the US east coast to the Bahamas
Send a message via AIM to Melrna Send a message via Yahoo to Melrna
Rocker
I can check the noise in neutral ,run up the engine and I get no squeal. The shaft doesn't turn. So I know the noise isn't coming from the engine itself. Only when I am in drive does it squeal. As far as the warranty issue I believe it does say the warranty does not transfer. The issues I have with Marine Air is, they are supposedly a reputable company, it is a manufactures defect, and it happened before I owned the boat.
Melissa Renee
Moondance
Catalina 445, Hull #90
Melrna is offline
post #14 of 15 Old 07-13-2008
Yes, but the noise might be coming from the gearbox when in gear?
Disconnecting the final drive coupling and listening for squeal, or none, would confirm that.
Rockter is offline
post #15 of 15 Old 07-14-2008
Courtney the Dancer
jrd22's Avatar
Sorry to hear of all the problems you are having with the new boat, some are to be expected but it sounds like you are getting more than your share.
I agree with Rockter, revving the engine in neutral will not tell you if it is a bearing in the trans. Even disconnecting the shaft coupling might not put enough pressure on it to cause it to squeal. If it is a bearing and oil sample should show some metal in it. That might be a good next step.
John
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
How loud is loud with an A4? jaschrumpf Atomic 4 2 08-21-2008 08:34 PM
When is it time to replace your autopilot? teshannon Gear & Maintenance 50 10-20-2007 09:46 PM
loud hailer on new catalina 440 knothead Gear & Maintenance 2 04-27-2006 01:00 PM
