Old 07-12-2008
mwrohde is on a distinguished road
Bottom cleaning
The boat is a 27 foot monohull (no rail mounted grill) that lives exclusively in fresh water. It's been about 18 months since it's been out of the water. The bottom was painted at that time. Now, the bottom is covered in snot.
I've worked a bit on the bottom with a brush on a long handle. The snot comes off pretty easily, as well as clouds of bottom paint.
Is this the correct procedure and expected results?
Thanks,
Matt
Old 07-12-2008
MoonSailer is on a distinguished road
I scuba or snorkleand use a soft sponge to clean my boat's bottom. no hard growths since I moved it from the coast to a lake. It is now almost 4 years since the last bottom paint. I ideal is to scrub just hard enough to remove the slime and as little paint as possible. On my lake I get a very dark slime that really slows boat speed. But it is easy to remove. It takes me less than an hour using scuba. A little longer with a snorkle. Much of it can be cleaned without going underwater. Cleaning the keel is the hardest without scuba as it is deepest and requires more trips to the surface to breath for the amount of cleaning time per breath.
Old 07-12-2008
camaraderie's Avatar
moderate?
Sounds like you have applied an ablative bottom paint and you are scrubbing it off along with the gunk. 18 months is a pretty good run so youare about due for a renewal anyway. Next time you haul...get the remaining paint off and use a hard bottom paint that will stand up to scrubbing instead of an ablative.
Old 07-13-2008
sander06 is on a distinguished road
Count yourself lucky that you're in freshwater and not salt. No barnacles to clean off and no sharks to eat the cleaner.
Old 07-13-2008
JohnBoelte's Avatar
JohnBoelte is on a distinguished road
As much as I dislike the short summertime/boating season in Indiana, I've found that not having to worry about being eaten by the marine life has a lot of virtue.
Cleaning bottom in water??? Stevyboy Gear & Maintenance 45 02-03-2009 02:42 AM
Confessions of a bottom feeder PracticalSailor Gear and Maintenance Articles 9 06-18-2008 04:33 PM
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
Scuba and bottom cleaning luckybear Gear & Maintenance 7 06-04-2001 05:21 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
