07-14-2008
I have always used bleach (Chlorox, pool chlorine, sodium hypochlorite solution) for cleaning stains, including crushed spiders, tree sap, bird droppings and Mississippi mud. Inexpensive, works well. Best to dilute it to 1% or less. Laundry bleach is usually 6% (dilute 5 parts water to one of Chlorox,) pool chlorine is usually 20% (dilute 19 to one with water,) and if you are familiar with the term "sodium hypochlorite" you probably know enough chemistry that I don't need to tell you how to dilute!
Don To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
1980 Endeavour 37 sloop, currently in the Mississippi near St Louis To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
