-   -   READ THIS TODAY-It may save you an engine or at least some time and money! (http://www.sailnet.com/forums/gear-maintenance/44973-read-today-may-save-you-engine-least-some-time-money.html)
Marleetet 07-14-2008 12:35 PM
I originally posted this in a "Hard starting engine" tread. But have decided that it is probably important enough to go out as general info.
What I am about to write maybe common knowledge, but I didn't know about it. The Yanmar rep and two mechanics didn’t guess it would be the problem.
I was having starting issues- or so I thought. 4 year old PDQ 34 with the 4JH3-TE and has always started fine the first try every try. Even the first time this year after having been out of the water for 20 months. Then, the starboard engine wouldn't start after a night on the hook. Checked batteries and swapped batteries with running engine and generator. Nothing. Took 6 hours to get home on one engine. Just for grins, charged battery with generator for thirty minutes- then it started. Started every time I tried for the rest of the day. Next morning, wouldn't start. Installed a new starter, started right away. Next morning wouldn't start. That afternoon wouldn't start. When mechanic came over in the morning it started, and everytime we tried the rest of the day. Since there is no more PDQ Whitby-not that they were ever of any real help, I contacted the Yanmar Distributor here in the Midwest. He guessed that it was at least one leaking injector. Blue Freighted them in- installed, and engine started like a champ. Next morning, engine won't start.
Just to be clear on what was happening when I was trying to start the engine. I would turn the key and there would be a "woo-woo" from the motor and then nothing. Turn the key again, and another "woo-woo" and then nothing. Sometimes after the third or forth attempt, not even a little "woo". More times than not, if the generator had been on and charging the battery, it would tend to start right away or at least within the first couple of tries. Right after the starter and the new injectors were installed, it started right away. But then the next day it would go through it's one or two "woos" and not start.
We even tried a new battery and a remote starter. Again, it would sometimes start after many tries or it wouldn't. It would always start right away if we were able to get it started once. Only after not starting it for 10 plus hours would it have it's problem.
After installing the injectors with no positive results, the Yanmar rep thought the starting issue might have been from leaking injectors and that there might be left over fuel that was not burning off just idling. So he wanted us to get it started and run the engine under load for 1 to 2 hours. It started on the first try. The engine sounded a little different, not bad, just different, and was actually running much smoother than the port engine. I attributed that possibly to the new injectors. The port engine, that has been running just fine showed 60 MP for oil and temperature smack in the middle. The bad engine showed about 55 MP for oil and also smack in the middle for temperature.
After about 10 minutes at 2500, all systems looking good, I ran it up to 3200 rpm (the turbos kick in around 2900 rpm) That is when the MP slowly, and I mean slowly started to drop to 40, No change in engine sound or rpm. When it went below 40 MP I shut down the engine. In the bilge was a whitish gray mixture with the consistancy oil. I check the dipstick and it was very dark.
From start to shutdown was about 30-40 minutes.
We one engined it back and with the mechanic, started to really probe. There was some whitish oil in the crankcase, but just a trace. Lots of whitish oil scum under the oil filler cap and attached to the number three cylinder rods. The oil in the bilge was very whitish gray. Wild case guess, I would say that there was a 1/4 to 1/2 quart of oil that had come out of the relief tube that empties just below the turbo.
Off came the head. What we saw was, that the number three cylinder was 3/4 full of lake water and had rust on the walls of the cylinder. 1, 2 and 4 looked perfect.
Had the head and exhaust pressure tested cold and hot- no cracks or warpage. Cylinders were tested for height against the case, and there seems to be no damage to the any internals.
Now keep in mind, there was no drop in rpm, except for running smoother than the “healthy” port engine, there were no sounds or indications other than the MP drop to indicate any problems what so ever.
There are quite a few people scratching their heads at Yanmar.
In my quest to figure out what my problem was, I was digging around in all sots of websites including the PDQ Forum. I spotted this post from the owners of MV Dana Louis back in 2005:
We suggest adding this to your maintenance checklist - especially after an extended layup/layover:
Sight check the clear tube running from the exhaust riser anti-siphon valve to the inboard hull vent fitting to make sure it is clear.
If that tube is obstructed [in our case by an insect family], on diesel shutdown the tube cannot break a vacuum in the exhaust loop and seawater is sucked back through the exhaust riser into the diesel. You know this has happened when you try to start and get almost no turnover [water does not compress] - or, if you are really unlucky, an engine that starts up on 3 cylinders and mangles the valves, piston etc in the cylinder with the water.
We were lucky on two counts - lots of water, preventing any possibility of starting, and an immediate diagnosis and recovery instructions from Chris Calvert. Three hours later, including the oil change, we were running nicely at 3200 rpm. Whew!
Well I check the anti-siphon tube on the bad engine and it was clean, but full of water and some anti-freeze. The valve that is the exit for the anti-siphon hose from the boat on the other hand had two small larvae and black fluid completely blocking the hole. When the hose was attached, I was unable to blow air through the valve. Once I cleaned it, air passed through the hose and valve unrestricted.
ARGGGGGH! So did I have two problems: a bad injector and larvae. Or just one problem: larvae.
This has been pretty expensive and time consuming. It could have been worse and still may be.
So all of you Yanmar owners having or not having some starting problems, check the anti-siphon system from the anti-siphon valve all the way to where it exits the boat.
harryhoratio 07-14-2008 12:46 PM
Excellent information - thanks for the post.
sailaway21 07-14-2008 02:01 PM
Earwigs, mud-daubers, wasps, bees, and a bunch of other insects are prone to climbing into the smallest of holes and making it home. When it has anything to do with a hydraulic system, usually in a vent tube that you may not even know you have (!), the symptoms are just plain odd. One might that that the hydraulic or pneumatic pressure in such situations would blow the blockage out. One would be wrong. Vent tubes are the easiest thing to clear and fix, and they're the last thing we look at, every time.
You've my condolences and empathy.
JohnRPollard 07-14-2008 02:39 PM
Intriguing mystery.
If indeed your problem was caused by the anti-siphon being blocked -- this is yet one more reason to close your intake through-hull when the engine is not in use!
This makes me wonder why you didn't mangle any valves, etc given how long this problem persisted and how many times you started the engine!? One way to find out whether your water lift muffler was backfilling would be to take a good look at it and see if it's over-full of water? If it's not, I doubt this problem was caused by the blocked anti-siphon line (which may not have been 100% blocked, it only takes a tiny bit of air to break the siphon).
Another possibility is that the boat got tilted excessively while being hauled out or re-launched, which can cause water to flow back from the water-lift muffler into the head. I know of at least one instance where this happened, resulting in a re-build.
One point of correction to the warning posted by the MV above: The raw water in the water-lift doesn't actually get sucked back through the exhaust riser, it merely back flows by gravity when the water level in the exhaust system reaches a point where it exceeds the high point of the elbow.
Vasco 07-14-2008 02:55 PM
Nothing worse than hydrolock! Saw a 3GM30F hydrolocked and started with a bang!! Bolts on the crankshaft sheared, rods bent! Engine written off! If your engine fails to start on the first or second crank shut the water intake.
Marleetet 07-14-2008 03:56 PM
JohnR- I don't know how we didn't either, and I won't be surprised if there is some unseen damage that rears it's head in the first few hours of operation.
The water was backed up all the way to the exhaust/water mixing elbow. Also, when I removed the siphon i heard some gurgling and a slight vacuum sound. The through hull valve for the anti-siphon hose was plug tight enough to not allow me to blow air through it and took some heavy wire to punch through the larvae.
I was there for the haul out and relaunch. Nothing out of the ordinary there.
The engineers at Yanmar and Mack Boring have my pictures, observations and have worked very closely with my mechanic. They haven't decided yet whether I had one or two problems. But they are still working on it.
I would also like to let you all know how impressed I have been with Bob at Mack Boring (Yanmar Reps in Chicago). He has promptly responded to every question and took it upon himself to follow up directly with my mechanic and with Yanmar. I promise you that you do not get to see this kind of service very often.
JohnRPollard 07-14-2008 04:28 PM
Originally Posted by Marleetet (Post 341165)
...The water was backed up all the way to the exhaust/water mixing elbow. Also, when I removed the siphon i heard some gurgling and a slight vacuum sound. The through hull valve for the anti-siphon hose was plug tight enough to not allow me to blow air through it and took some heavy wire to punch through the larvae. ...
Well, that about clinches it, eh? :eek:
Not that this hasn't already been a royal pain, but here's hoping you come back with an update -- to the effect you got lucky with no terminal damage!:)
