Old 07-16-2008
hd1975 is on a distinguished road
Question bilge pump not working
I'm back with a problem--bilge pump on a cape dory 27 (on the side of cockpit area) doesn't seem to suck any water unless you pump handle like a maniac. Any suggestions are where to start looking for a remedy and does anyone know if you can replace unit? thanks as always
Old 07-16-2008
Would help if you said what make/model pump it was. In any case, you might be able to rebuild it. If it is a diaphragm-type pump, the diaphragm might have a small hole in it.
Old 07-16-2008
speciald's Avatar
Special Delivery
speciald is on a distinguished road
Send a message via Skype™ to speciald
Agree - check the diaphragm. They eventually will break down in Summer heat and usually can be replaced. You must have an air leak somewhere.
Old 07-16-2008
Quickstep192 is on a distinguished road
My manual bilge pump looks more or less like the one in the picture. The diaphram develops small cracks and can't hold suction. There's a re-build kit that's pretty easty to install.
Old 07-16-2008
SVDistantStar's Avatar
'72 Pearson 36
SVDistantStar is on a distinguished road
Send a message via AIM to SVDistantStar
Check the hose running to the bilge. Mine has a couple of small holes in it that made the pump act like yours. Duct tape works untill i buy a new hose.
1972 Pearson 36 S.V. Distant Star
Old 07-16-2008
capttb is on a distinguished road
You also may want to check the hose intake in the bilge, some folks put a piece of screen on it that can clog.
Old 07-16-2008
mwrohde is on a distinguished road
The check valve (really just a rubber flap) in mine broke off which prevented it from drawing a prime. I plumbed a check valve into the line to replace it and the pump works fine.
Old 07-16-2008
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Diaphragm pumps have rubber flappers on the inlet and outlet side of the round bit (called check valves).
If you can't find any obvious problems with the hoses, it's very possible some rubbish has got though your filter and jammed under one of these - it doesn't take much. You'll have to take the diaphragm off to check it (just undo the hose clamp), but make sure you put it back nice and tight or it won't seal.
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 07-16-2008
JimsCAL's Avatar
JimsCAL is on a distinguished road
My vote is that the valves are bad. Buy a rebuild kit which will inlcude those. Had to do this last year with my Whale 10 when it started acting exactly as you describe. Valves were toast.
Old 07-17-2008
Omatako's Avatar
Omatako will become famous soon enough
Yeah I'm with jimsCAL on this. The valves in these whale type pumps harden and don't seal properly.
The symptoms you mention would have me looking at the valves first.
Andre
Devising a Better Bilge Pump Don Casey Seamanship Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Cruising Articles 0 06-02-2002 08:00 PM
