Old 07-17-2008
Gaspilot is on a distinguished road
Converting to cutter rig.
NOTE: This thread has been moved from the Sailboat Design and Technology Forum Rules for posting. Jeff H- Sailnet Moderator
I have my 30' sloop on the hard for a complete re-fit. I have drawn up the geometry etc for adding a bowsprit. I have already added an inner forestay.
My question is: Has anyone experience or advice on a project like this. My reason for doing it is I want to experiment with various sizes of head sail that can be flown on any combination of the three forestays thus allowing large areas in light airs but still being able to get down to the storm jib if things get busy. I am also condsidering adding a yawl rig mizzen maybe to balance the rig. I would love to hear from anyone with experience/advice on this.
Gaspilot.
"....Procrastination is the thief of time...."
Old 07-17-2008
Jeff_H's Avatar
Super Moderator
I have been involved in a number of projects like this, mostly on larger boats. Frankly, on a normal and reasonably well designed 30 footer, it makes very little sense to add an inner forestay, no less a bowsprit, or mizzen. A 30 footer generally does not need and is greatly damaged by the extra weight aloft, and the extra complexity and difficulty in handling implied by the extra rigging that you are contemplating adding. I would think that you would really screw up most 30 footers doing what you arfe proposing and have done already.
If you really want to add sail area in lighter air that you can use above a beam reach, then perhaps you should consider adding a code 0 to your sail inventory and adding a spinnaker for broad reaches and runs.
Old 07-17-2008
EO32's Avatar
EO32 is on a distinguished road
I have a cutter and it is really a pain to tack my 135 genny through the slot between the front stay and stay sail.
On the other hand, I was out this last weekend, we wanted to just hang out on the water, so I had all sails down, except the stay sail, which self tacks. The wind was up, so we just poked around with stay sail, not worrying about gybing or tacking. It didn't point worth a damn.
If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps better than most. A small sailing craft is not only beautiful, it is seductive and full of strange promise and the hint of trouble.
- E.B. White
Old 07-17-2008
EO32-
You need some mainsail up to really point.
Old 07-17-2008
RXBOT is on a distinguished road
Eo32
Why not attach inner stay with a highfield lever, remove for the genoa put back in place for storm gib.
Old 07-17-2008
jrd22's Avatar
Courtney the Dancer
I have to agree with Jeff, you are adding weight and complexity to a relatively small boat that was designed to sail as a sloop. Spinn's and asym's are for light air and don't mess up the design.
John
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 07-17-2008
EO32's Avatar
Not a bad idea, but I like the look of the cutter.
Also I rigged a solution, I call the "Genny Puller". It's a small line attached to the foot of the Genoa about a third of the distance from the tack and runs to a block on the pulpit and back to the cockpit.
When I tack, the Genoa lays up on the stay sail, then I pull the "Genny Puller" which slides more sail forward into the slot. The wind catches it and pulls it through the slot. So far it's been working good. Better than having to go forward and yank it through by hand on each tack.
- E.B. White
Old 07-18-2008
JackDawson is on a distinguished road
Jeff, do you really think the weight of an inner stay added to a rig would be damaging? What's that, like 10lbs of wire on a 30 foot boat?
Nothing wrong with a staysail on a 30 foot boat when conditions warrant it. It's one thing to be racing with crew and another to be singlehanding on a long trip - tired and wet - and need to handle a big sail in a blow. That staysail with its attendant annoyances pays for itself.
Eo32: Nice idea with your genny puller!
Ketch vs Sloop? bobmcd Boat Review and Purchase Forum 24 05-11-2010 03:35 AM
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Ketch/Yawl Handling svsymphony Seamanship 19 07-05-2008 01:19 AM
Sloop or Ketch? maxheadspace Boat Review and Purchase Forum 46 07-27-2007 02:56 PM
Yawl Info Needed sailortonyb1 Boat Review and Purchase Forum 5 01-18-2006 04:51 AM
