07-18-2008
Best Looking Moderator
Originally Posted by max-on
Now that you guys have managed to hijack my inquiry, thanks.
SD, I agree.
Ok smartas(I will leave remaining letters blank as Cam will just delete anyways as some of the pus(oh leave those letters out too) around here will be offended), what would you recommend.
I do not like your choice for many reasons.
First, it does not have a lot of pockets which you will need. You don't want to keep going up and down the mast or you will lose your help. Not to mention, once up there, you need will want to get it done and get down. It needs to have a pocket(s) big enough for a cordless drill and a mesh small enough to hold screws. I like also having a line hanging off so you can tie some tools to it (or as I use it, to safely secure some tools should you accidenally drop them).
As SD mentioned, it will be hot and sitcky. I strongly prefer fabric.
Also, I think that would hurt my back after a while. My strong perference is for a hard seat where I can wiggle some to releave pressure off my back. I have a disc problem at L5-S1, which amplifies this issue. I think it would kill my back after a while. The hard bottoms are better, I have found, at allowing you to wiggle some to relieve pressure.
I believe mine is the Plastimo, but Harken makes one similar. Mine is the Professional model as I recall, but I will double check this weekend. You can review them at this site:
Plastimo USA
You can purchase them here or anywhere else of your choice:
Plastimo Professional bosun’s chair Shop.Sailnet.com - sailing resources, shopping, sail, blogs
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
