Old 07-18-2008
bootneck is on a distinguished road
bootneck
I have an ABI manual windlass about ten years old, which has been lightly used. What maintenance procedures should I perform and what grease should I use?
Old 07-18-2008
Take the windlass apart
clean the bearings and parts in gasoline or kerosene
Apply light oil to the pawls and springs
Apply heavy grease to the bearing surfaces of the windlass
Re-assemble
Old 07-18-2008
Thanks for the quick response!
Old 07-18-2008
One other thing... if any parts are heavily worn or damaged... replace them ASAP.
Finally, I highly recommend you read the post in my signature...since your Opening Post basically sucks...
For instance:
  • You don't say what specific model windlass you have. Different models may often have different maintenance requirements.
  • Your thread title "Bootneck" really sucks rocks...cause it doesn't have anything to do with the topic of the thread.
Welcome to sailnet.
Old 07-18-2008
Omatako's Avatar
Omatako will become famous soon enough
  • You don't say whether the windlass is electric or manual—an electric windlass will often have more maintenance requirements.
Welcome to sailnet.
Aw, come on SD
  • OP did say it was a manual windlass
  • The info you provided on maintenance was good but not in any way model-specific.
But I suppose you're right, the title sucked.
Andre
Old 07-19-2008
New to Sailnet
Sailing Dog, i screwed up the title, won't happen again. However read my first post. It clearly states ABI manual windlass.
Old 07-19-2008
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
Way to make a new guy welcome SD
Old 07-20-2008
sander06 is on a distinguished road
Pleez!!!! Don't clean stuff in gasoline!! Gasoline is toxic as hell and extraordinarily flamable (and will burn you to a little pile of rubble)!
I will now resume normal breathing and heart-rate.
Cheers,
Steve
Old 07-20-2008
Rockter will become famous soon enough
Oh man, what a welcome for a new poster.
Maybe he doesn't know windlasses?
Ease up Saildog.
Old 07-20-2008
What model is the Windlass?
There should be a picture on the net.
Generally the maintainence should be minimal, and it hasn't had much use.
