  #11 (permalink)
Old 07-20-2008
Use a plastic "razor blade". They're pretty much designed for this situation and probably won't damage the Lexan. They sell them at West Marine, among other places. Same shape and size as a single edge razor basically, and does much the same as the single edge razor in terms of scraping, with far less potential for damage.
  #12 (permalink)
Old 07-21-2008
johnshasteen's Avatar
johnshasteen is on a distinguished road
I have Lexan ports also and had the same problem - but the mess was made by me. Use a plastic scraper and gently get all you can with that. Then use either Goo-Gone or WD40 to remove what's left - neither of those products will hurt plastic or Lexan.
s/v Paloma, Bristol 29.9, #141
Slipped in Bahia Marina, easy access to Corpus Christi Bay and the Gulf of Mexico.
  #13 (permalink)
Old 07-21-2008
Gary1 is on a distinguished road
Yes, stay away from solvent based cleaners like acetone, lacquer thinner, etc. They'll eat Lexan alive!
Cap'n Gary
do i need to remove rudder to remove shaft 37cc jumpnkd Irwin 4 04-13-2008 10:48 AM
Can I remove the babystay and the engine? hkg4237 Gear & Maintenance 4 09-17-2007 07:39 PM
Installing Lexan Windows fraser36 Gear & Maintenance 12 06-28-2007 10:31 PM
how to remove folding prop? mcagney Gear & Maintenance 1 07-20-2005 10:23 AM
Restoring Lexan Surfaces Sue & Larry Gear and Maintenance Articles 0 02-10-2002 07:00 PM
