Old 07-21-2008
Stateofmind42 is on a distinguished road
Removal of Vinyl Adhesive
Any advice on how to remove the ugly discolored vinyl adhesive from our Novurania RIB? We unknowingly were over zealous when spreading the adhesive to apply the "numbers." It was clear going on, but now as you can see, it is brown. Any advice would be greatly appreciated. Thanks much,
Old 07-21-2008
camaraderie's Avatar
moderate?
Without knowing the adhesive it is tough to say what to use and whether it would have a damaging effect on the PVC/Hypalon of the dinghy. I would first suggest a heat gun and scaper to see if the glue can be softened and removed. Alternatively, you may just wish to cover the whole thing up with a piece of white vinyl cut to size and glue new numbers to that.
Old 07-21-2008
You could also try goo-gone, which removes a lot of common adhesives.
Old 07-21-2008
Junior Birdman
Iflyka200s is on a distinguished road
Handsome lookin' pup!
1988 Seaward Fox
no name yet (it's in pieces!)
Coconut Grove, Florida
Old 07-21-2008
landlockvasailor's Avatar
landlockvasailor is on a distinguished road
I would wait until the season was over or whwn I was ashore for extended time and call the maker. Surely this has happen before and they would hopefully have a solution. They may save you another problem.
Yep, I agree, cute pup
When I go, let it be by boat, with a steady breeze on the Chesapeake with a bottle of 7-up, a bag of ice, a plastic cup, and a box of wine
Old 07-22-2008
Gary1 is on a distinguished road
You might try 3M adhesive remover. It's mostly naptha (from the smell) which won't hurt hypalon or PVC. I think WM carries it, but I'd look for an auto body paint supply house first. They'll be cheaper than Worst Marine.
Cap'n Gary
Pulled out old foam back vinyl from berths...what now? pata_grande Gear & Maintenance 4 02-13-2008 07:20 AM
