07-22-2008
When a dripless seal starts leaking, it means one of a couple of things:
The cutlass bearing may be shot, allowing the shaft to be slightly out of alignment.
The seal itself is just plain worn out.
Worst case: the shaft is bent.
A tip: If you want to pull the whole unit off without hauling the boat, you can plug the hole where the shaft enters the hull with the wax material from a household toilet seal. Jam a rag into the hole first until it's tight, then pack the wax around to seal it. This will hold for several days.
Cap'n Gary To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
