Old 07-22-2008
jbondy's Avatar
Senior Mumble
jbondy is on a distinguished road
Headliner Seem Material
In the v-berth, there is a two-piece fiberglass headliner that comes together in a line that runs fore and aft. To cover the seam, there is a 4" wide indent in which was glued what appears to be an 8' x 4" piece of cardboard wrapped in ugly grey vinyl. Over the years it has has gotten no prettier, has shrunk and is peeling off. I'd like to replace it with something. I guess they used the material they did because there are some bends it has to make as the ceiling curves to follow the underside of the anchor locker above. Length-wise it's straight - the bends are up and down. My preference would be wood, maybe teak veneer, but I've never worked with eneer and don't know how it would handle the curves. The pic below is from a sistership on Yachtworld.
Any suggestions? Thanks in advance.
Old 07-22-2008
Jbondy-
Might be worth checking out the headliner thread I started about two weeks ago.
Old 07-22-2008
jbondy's Avatar
Senior Mumble
Thanks, Dog. I actually had added a couple of posts to that thread suggesting hole plugs to cover nuts/bolts and to show the headliner we installed in the saloon. Are you suggesting the Komotex material mentioned in that thread might be flexible enough for this application?
Old 07-22-2008
beej67's Avatar
beej67 is on a distinguished road
I have the same boat, and the same issue, although it's fairly low on my priority list currently. If I were to fix it, I think I'd just buy some hardwood from a lumber supplier and cut it all to fit / route the edges / etc.
beej67, Checkered Past, 1980 32' Pearson 323, Panama City FL
Old 07-22-2008
jbondy's Avatar
Senior Mumble
beej, I hear ya about position on the honeydew list. If mine looked as nice as the one in the pic, i.e. it hasn't fallen enough to annoy when trying to sleep in the v-berth, it would be lower on mine, too! Anyway, your approach makes it a harder job than I was anticipating. Difficulty lowers things on the list, especially when cosmetic.
Old 07-22-2008
Depending on thickness, it probably would work.
Old 07-22-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
Use, Luan plywood which is cheap and a mahogany veneer. It would also bend and curve to fit into that space. With a couple of coats of varnish it would look great. It would also come close to matching the other wood that I see in the picture.
S/V Scheherazade
Old 07-22-2008
jbondy's Avatar
Senior Mumble
Freesail, Thanks for the suggestion. How thick is Luan? Do you have to do anything to it to make it bend? Would you use contact adhesive in this application?
TIA
Old 07-22-2008
Freesail99's Avatar
Luan can be found, in either 1/8 or 1/4 inch thickness. Contact Adhesive or brass screws would work. Go to home depot they carry it, see how bendable it is.
S/V Scheherazade
Old 07-22-2008
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Luan is the same material used to make those hollow wooden interior doors, it is light and flexible and can be made more flexible by either scoring the back with kerfs or soaking in amonia (makes it nice and bendy by raises the grain a tad). Normally I find the qrain a little open and hard to smooth without filler but a quick coat with epoxy and varish will make it nice, double rows of brass screws would make it very shippy.
Three ways to fix dodger windows GoodOldBoat Gear & Maintenance 2 11-05-2008 05:37 PM
CAL 27 Sound deadening/insulating ? material lining sides of Engine Compartment H216Sailor Gear & Maintenance 4 04-19-2008 02:54 PM
Need material to raise floor of bilge slightly saltypat Gear & Maintenance 5 09-20-2007 07:30 PM
Under Cushion Material Ronbye General Discussion (sailing related) 16 06-29-2007 10:28 AM
rudder bushing material, loads Burnsy Gear & Maintenance 2 01-22-2004 06:36 PM
