07-22-2008
IF the aluminum frame is in good shape, I would recommend still using them. Many of the more contemporary boats use much what you're friend suggested—oversized lexan ports held via through-bolts.
If you decide to go with the oversized lexan ports, remember to drill the holes oversized, chamfer/countersink both sides of the holes and to use a good sealant like butyl tape. The holes really need to be oversized so the ports can expand and contract a bit—as they have a different expansion coefficient than does fiberglass. The chamfering of the holes will help prevent stress cracks from forming at the holes.
Really recommend you not use 5200 for the ports. IMHO, that is a really bad idea.
I would also recommend you paint the outer 1" or so of the ports with black paint, preferably on the "inside" to hide the sealant and leave a nice clean appearance to the installation.
