Raw Water Cooling - No Water Coming Out - Page 3 - SailNet Community
post #21 of 21 Old 01-21-2009
so... story continues.. I got a tapered brass nozzle and shut off valve for my garden hose, and I clamped off the return hose (bypass), I put the nozzle into the crossover hose and connected the thermostat housing to a hose emptying into a bottle. But, i couldn't blast through that direction. So, I reversed it, putting the bottle on the crossover, and the nozzle into the thermostat housing and was able to blast it out. Then, I reversed it again, and was able to get flow. Once I flushed it a while, I put everything back together the correct way except I left the thermostat out, and started her up. She ran well and kept a good temp. A steady stream of water came out the exhaust, but not enough. Not even a steady pouring. So, I think maybe it got reblocked, and I'll need to flush it thoroughly and try again. I just don't want to use acid if I don't have to yet. I'll keep you posted! And thanks again!
jasongael is offline
raw water pump leak on Yanmar 3Gm30F gsyversen Gear & Maintenance 24 06-13-2008 02:34 AM
Raw water cooling - removing scale Tomaz Gear & Maintenance 6 09-02-2007 02:16 PM
Oday 30 Raw water flow and folding props deniseO30 O'Day 2 08-13-2007 09:25 AM
Raw water pump bestfriend Gear & Maintenance 56 04-26-2007 10:03 AM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 08:00 PM
