07-23-2008
Harp-
It would really help if you said what size batteries you have.
If you're running the GPS, a VHF, running lights and a stereo...you will need a fairly big battery bank.
If you're just running the GPS... even most small battery banks will be able to handle it for 10 hours.
The current draw on a Garmin 440s is about 1.5 amps. So, to run it alone for 10 hours, you'd draw 15 amp hours. A Group 24 battery has about 90 amp-hours, of which you should only use 45 amp-hours... so you'd be able to run it for about three days @ 10 hours per day before needing to recharge the battery.
BTW, you really should read the post in my signature.
