07-24-2008
Originally Posted by saurav16
halekai36,
Thanks for the response but I am not mismatching threads, I bought a groco sea **** and a thru hull. The flanged seacock base has a female nps the thrull which will be mated to the the seacock is male nps. I was wondering if you use teflon tape for the NPS fitting?
http://www.defender.com/product.jsp?path=-1|51|106370|813148|319675|860855&id=860619
http://www.defender.com/product.jsp?path=-1|51|106370|316448|315121&id=992827
links to what i bought.
Sorry I misunderstood that you had a flanged adapter.
That side of the flanged base gets what ever bedding compound you choose to use. The head of the mushroom makes the seal and you simply wipe 4200 or Sikaflex 291 on the threads, and generously around the head, and screw it in.
You also bed the underneath of the flange. You are not creating a water tight seal with the NPS threads and the seal is at the flange base, you'll note a groove around the thread insertion point, and the mushroom head. The marine sealant does help to keep it water tight but really the threads could go in dry if you have done everything else right..
______
-Maine Sail / CS-36T
