Changing A Raw Water Impeller (How To) - SailNet Community
 3Likes
post #1 of 43 Old 07-24-2008 Thread Starter
Maine Sail's Avatar
Hi All,
I just changed my impeller, second one this season, and this time I finally remembered to bring my camera.
I've noticed a string of overheating threads recently popping up here and on other forums so I thought this new photo based article may help some who are not totally familiar or comfortable with the task.
______
-Maine Sail / CS-36T
Maine Sail is offline
The Following User Says Thank You to Maine Sail For This Useful Post:
sailinggreg (10-29-2014)
post #2 of 43 Old 07-24-2008
Nicely done.
sailingdog is offline
post #3 of 43 Old 07-24-2008
brianontheroad's Avatar
couldn't ask for more!
Great post/article -- especially since I have the exact same impeller/water pump system on my Westerbeke 27 that I'm going to have to replace tomorrow
brianontheroad is offline
post #4 of 43 Old 07-24-2008
moderate?
camaraderie's Avatar
Excellent as usual Halekai! Thanks.
camaraderie is offline
post #5 of 43 Old 07-25-2008
Pamlicotraveler's Avatar
As I said this job is very, very easy. If you can change oil or an air filter or clean a blender after making frozen "chick drinks" you can change an impeller.
Halekai,
Your illustrated guides are very helpful. Really good. (did you do the stuffing box illustration a while back? You must have. I have saved it and used it)
With the impellor I have avoided changing mine on my Yanmar 4jh because it seems so inaccessible. There is no way you could take pictures like what you have here. I am certain I would drop one of the screws for the plate, or probably the plate itself, into the bilge and that "20 minute job" would ruin a sailing weekend or end up in me utilizing my unlimited Sea Tow policy
I have a spare impeller and the tools to change it, ie bent needle-nose pliers etc, and I think I can do it when I need to. But I really wonder why Yanmar puts the impeller case on the backside of the pump since it considered a maintenance item. It has to be done by feel - at least I don't have any mirrors that would work.
Anyway...thanks for the great explanation and illustration.
"Tell 'em I'm busy. I'm on a sails call."
Pamlicotraveler is offline
post #6 of 43 Old 07-25-2008
Tartan 37C
T37SOLARE's Avatar
Halekai,
Another GREAT post, thanks!
Pamlicotraveler,
My raw water pump is also not the most accessible, and with my eyesight and bad back, changing it in a seaway would be next to impossible. This past winter I retrofitted the cover with a
Speedseal and I am very happy with the results.
SOLARE
T-37 #442
T37SOLARE is offline
post #7 of 43 Old 07-25-2008
Location: Aboard SoulMates somewhere in the Eastern Med
SoulMates is a Jeanneau DS40 and has a Yanmar JH4 engine - maybe the issue is not yanmar but the engine access the boat mfg gives you - Jeanneau gives great access (at least i have it) and changing the impeller can be done without a lot of trouble -
i would suggest that you do it at the dock before thinking you can do it at sea - it took me a while to figure it out at the dock but now i know i can do it at sea - may not be easy but i will have the confidence that i can do it - I did use a wire tie to get it in place and once i figured that out it was a breeze -
just my thoughts
chuck and svsoulmates
ki4sry
fulltime cruiser - on the hook in cambridge,md
chuck5499 is offline
post #8 of 43 Old 07-25-2008
just my thoughts
ki4sry
post #9 of 43 Old 07-25-2008
Freesail99's Avatar
If possible, try and duck tape the bottom end of a cut up plastic bottle or container to catch anything, that might fall.
S/V Scheherazade
Freesail99 is offline
post #10 of 43 Old 07-25-2008
Freesail99's Avatar
S/V Scheherazade
raw water anti siphon/vented loop? deniseO30 Gear & Maintenance 16 05-28-2008 12:12 PM
Raw water pump bestfriend Gear & Maintenance 56 04-26-2007 10:03 AM
Gifts from the Rain Gods Doreen Gounard Cruising Articles 0 03-18-2004 08:00 PM
leak from engine raw water siphon break i670684 Gear & Maintenance 2 08-11-2003 06:53 AM
Raw Water in Engine wmwtlw Gear & Maintenance 3 02-25-2001 12:31 PM
