07-25-2008
64 HP is likely to be plenty. Although my Endeavour is 5 feet shorter than your boat, she weighed 21000 lbs when she left the factory. Add 105 gal fresh water, 50 gal diesel fuel, and all the stuff the Admiral and I put on and she totals over 22k. We can go at hull speed with our 50hp Perkins diesel, which is now 28 years old. Parts for an old Perkins are usually available from a Caterpillar dealer, and reasonably priced. Caterpiller Tractor Co is the current US distributor for Perkins, an English company. Filters, belts, gaskets, pump impellers and such (which is all I have needed so far) cost me less than they did for the 9 HP Yanmar I had on my O'day! Unless the existing Perkins is in pretty terrible shape, I would be reluctant to replace it.
Don To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
1980 Endeavour 37 sloop, currently in the Mississippi near St Louis To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
