07-25-2008
Sorry SD, no pics. I can't get at the boat until next weekend.
I can tell you that the existing patch is faired out JBweld that is in a roughly 1'X1'X1' triangle spanning around the whole stern of the hull where it meets the transom.
The damage was from a pretty solid grounding on one of those random chunks of granite that have made Maine's inland lakes so popular for recreational boating.
I wondered if FRP would work. Thanks, Jeff, I will put that firmly on the "possible solution" list.
This boat is not meant to be pretty and not trying to set any speed records. We use it to puts around the lake, do the occasional water-ski, and beach it on gravel-ly beaches.
WIth that in mind, I was wondering if simply covering the entire patch with a half a tube of 5200 would work. I'm sure it would seal it, but I wonder if it would last. I would have to assume there is some flex in the hull back there...
Thoughts? Or rotten fruit?
S/V Gracie
P303
