Old 07-25-2008
marinesniper is on a distinguished road
Yanmar smoking out rear
The prop is very dirty, so when in drive the boat moves very slowly even under full power...is this normal...?
Also alot of smoke and black stuff is comming out the back of the boat...could the gunked up prop cause the engine to work to hard and cause smoking and black crud...? if not what is the most likely cause...?
thank you,
1981 - 30' Lippincott cruise/racer Miami, FL
One shot one kill !
Old 07-25-2008
chris_gee is on a distinguished road
Yep. Normal.
Old 07-25-2008
The black smoke is normal because the prop is heavily cruded...? The black smoke is only at high RPM...the engine starts very easy. One last thing, I notice that when in nuetral at high rpm there is not as much smoke...?
Is this all normal...?
thanks alot....!
One shot one kill !
Old 07-25-2008
djodenda's Avatar
djodenda will become famous soon enough djodenda will become famous soon enough
Yep. Normal. Clean the prop for happiness!
David
1987 CS 36 Merlin "Kyrie"
Old 07-25-2008
SteveInMD is on a distinguished road
Yes - you need to clean your bottom. All the extra carbon will accelerate the clogging of your exhaust system.
Old 07-26-2008
Gary1 is on a distinguished road
Clean the prop and bottom. Running things with a really dirty prop will also tear up your transmission, particularly reverse gear.
Cap'n Gary
Need help YANMAR engine mount Giulietta Gear & Maintenance 20 04-15-2010 01:15 PM
Smoking in the Boy's Room sailaway21 Off Topic 202 08-07-2008 12:30 AM
Yanmar Engine Mount Specifications HenryTully Gear & Maintenance 4 06-27-2008 10:20 AM
Yanmar 3gmd Question nk235 Gear & Maintenance 4 03-12-2008 04:48 PM
ATF or SAE ? Yanmar 4JH2E / Trans: KM4A TAK Gear & Maintenance 4 11-05-2007 10:34 PM
