Old 07-25-2008
landlockvasailor's Avatar
landlockvasailor is on a distinguished road
What should # 16 or #15 used winch Cost
Need an idea on what I should pay for a set of chromed, old, in good shape winches for cockpit, any input would be appreciated.
LL
When I go, let it be by boat, with a steady breeze on the Chesapeake with a bottle of 7-up, a bag of ice, a plastic cup, and a box of wine
Old 07-25-2008
depends on brand, age, material, whether they're self tailing or not, etc.
Old 07-25-2008
SD
Don't know the age, may be around 10 to 20 years, chrome, Harken, I think. My wife found them at a flea market in North Carolina and mostly guy will be there tomorrow. He is not a sailor, just pulled out of an estate sale.
Old 07-25-2008
Given that you can get new Harken 16 winches are about $400... if you can get the two winches for $175-250 for the pair, that would be a really good deal. Anything over $300 for the pair is a bit high IMHO, given their age.
Good luck. Chances are pretty good that an estate sale guy might not know what they're worth and you'll be able to talk him into selling them for a really good price.
Old 07-25-2008
Thanks, I don't want to take advantage of him, but I think I offer $150 each.
Thanks SD for your advice.
LL
Old 07-25-2008
Remember to rotate the drums... if the drums rotate easily and you can hear the pawls clicking into place with a crisp click, the guts are probably in pretty good shape.
If the drums are stiff and don't want to turn, the winches may have an internal corrosion problem. If the pawls don't click...they might have a corrosion problem or need a good clean/lube/adjust.
If the drums turn easily but feel gritty...the bearings probably got sand in them. This means, they're probably going to need a new set of bearings at a minimum, and possible a new spindle.
I hope that helps
Old 07-25-2008
Thanks ! I let you know how it goes.
LL
Calculating the Cost of Cruising Paul & Sheryl Shard Cruising Articles 0 04-03-2003 07:00 PM
It's Winch Servicing Time Tom Wood Gear and Maintenance Articles 0 10-17-2002 08:00 PM
It's Winch Servicing Time Tom Wood Her Sailnet Articles 0 10-17-2002 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
