Blogs
User Name
Old 07-26-2008
Martinini's Avatar
Martinini Martinini is offline
Martinini is on a distinguished road
Clean my Water tank
Whats the best way to clean out fresh water tank? Boat has been sitting awhile and the water coming out of spigots is kinda greenish brown.
Old 07-26-2008
fcsob fcsob is offline
fcsob is on a distinguished road
How to Sanitize Your RV Fresh Water System
Old 07-26-2008
BarryL's Avatar
BarryL BarryL is offline
BarryL is on a distinguished road
Hello,
Does your tank have an inspection port? If not, you really need to add one. My last boat did not have an inspection port, and when I looked into the tank I could see slime, dirt, and other bad things inside the tank. I added an inspection port (easy to do). I can fit my arm inside the tank so I can scrub the sides of the tank and get it very clean.
After the tank is clean I add water and sanitize it as described in the above article.
My current boat came with inspection ports and the tanks were much cleaner.
I still won't drink the water in the tank, but I don't mind using it for cooking and cleaning.
Good luck,
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
lenoble@optonline.net
Sponsored Ad
Old 07-26-2008
camaraderie's Avatar
camaraderie camaraderie is offline
moderate?
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
Martinini...
Try this thread.
http://www.sailnet.com/forums/genera...tml#post322874
Moderation in temper is always a virtue; but moderation in principle is always a vice....Thomas Paine
Old 07-29-2008
Martinini's Avatar
It took everyone at the Marina to find the inspection port, but we did. It was in a wierd spot under V-Berth. Thanks for all the info.
Old 07-29-2008
jimfortuna jimfortuna is offline
jimfortuna is on a distinguished road
Chloride attacks Stainless Steel
Chlorine is a great way to make your water safe, but if you have a stainless steel tank, it can cause serious long term metallurgical damage that is not initially apparent. Chloride attack can damage the stainless, particularly at welds, and can be destructive of other metal components in your faucets and pump housings.
Chlorides will attack the stainless and make it quite brittle over time, permitting hairline cracks to develop near welds and stress areas followed by mysterious leaks that are difficult to locate. This can be very problematic in the hot water system.
I would suggest that you careful to flush out the system with clean water after the chlorine "shock" treatment. It generaly takes a while for the damage to occur, but having highly chlorinated water sit without motion will cause damage faster.
Polyethylene tanks are likely ok with chlorides, but all the metal components exposed in the system can be affected.
Old 07-29-2008
RAGTIMEDON's Avatar
RAGTIMEDON RAGTIMEDON is offline
RAGTIMEDON is on a distinguished road
If you have a metal tank, you might also have baffles in it and need an inspection port between each baffle. My boat came with a 110 gallon aluminum tank seperated into three sections with a partial wall between them to limit sloshing of the water. Although there was an inspection port, 2/3 of the tank was inaccessable. I put in two more large ports to make it possible to clean the tank. With an aluminum tank you should not add chlorine, but with stainless it should be no problem unless you add too much. A teaspoonful of common household bleach (sodium hypochlorate solution) for every 10 gallons will make the water safe to drink, but may not taste good. One of the "undersink filter systems" sold in every hardware store will take care of the taste. Change the filter annually. I know Jim said chlorides will attack stainless, but think about it. City water in every city of the US is chlorinated, plumbing pipes in your house are copper, your faucets are either a brass alloy or stainless. Had any faucets crack lately? No, I wouldn't put chlorine in any form, bleach or anything else, in an aluminum tank, but a small amount of it will not cause a problem with other metals and can keep you from a bacterial infection! Aluminum is one metal particularly suseptible to chlorine attack, but stainless seems to resist the chlorine in salt water quite well! Salt is sodium chloride, and most sailors know aluminum becomes pitted when used on a blue water boat.
Don
1980 Endeavour 37 sloop, currently in the Mississippi near St Louis
Display Modes
vB code is On
the water in your tanks pegasus1457 Cruising 44 06-25-2008 06:49 PM
Potable Water tdw Provisioning 31 08-11-2007 08:30 AM
removing orig water tank zeilfanaat Gear & Maintenance 6 04-12-2004 07:26 AM
Watermakers Don Casey Miscellaneous 0 02-01-2004 08:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 08:00 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
