lightning protection - Page 3 - SailNet Community
post #21 of 75 Old 08-21-2008
teshannon's Avatar
The boat that got hit by lightning in my marina a few weeks ago had a grounding system. Maybe that's why they got hit. Most but not all of their electronics were fried. When the boat was hauled the thru hulls were fine but the grounding plate was still it's original color. I'm told it should have turned pink. I'm not sure if that means his grounding system was not wired propoerly but in any case the system, such as it was, did not help them much. I'm with SD, if you're happy with what you have leave it alone.
teshannon is offline
post #22 of 75 Old 08-21-2008
ASA and PSIA Instructor
..... However, there is evidence that grounded boats do get hit more often...
OK, I'll bite, can you reference us to the evidence that grounded boats are struck more often...I personally think that is an urban myth...
sailingfool is online now
post #23 of 75 Old 08-21-2008
Once known as Hartley18
Classic30's Avatar
Dock
Maybe someone's done the research - maybe they haven't. At the end of the day, what matters is what happens to *your boat* when the clouds are overhead.
The truth is that lightning doesn't obey the laws of man. Grounding the boat is no guarantee it's going to come out unscathed - it's more of a "Mister Lightning please travel this way and don't hurt my pretty boat - thank you!" suggestion. Lightning does whatever it blooming likes.
If it helps, most countries have fairly comprehensive Lightning Protection standards (like AS/NZS 1768) which are reasonably easy to read and can go a long way to dispelling myths.
I'd suggest the first thing anyone worried about this should do is get a copy of the latest "thunder days" map for your area from the Met Bureau... and then make sure you park in a clear spot.
Classic30 is offline
post #24 of 75 Old 08-22-2008
"Maybe someone's done the research "
No maybe about it, the folks who know how to deal with lightning are all in the broadcast engineering industry. You know, the guys who hold up the sign that says "TECHNICAL DIFFICULTIES, PLEASE STAND BY" on your TV?
Radio and television antenna towers are lightning magnets. Antenna towers are routinely over 1000 feet tall, out in the middle of nowhere, and built all of metal with metal guy cables. Some are closer to 1/4 mile tall. Then there are sites like the Empire State Building, which was capped with the broadcast antennas for most of the network anchors in NYC before the WTC was built with the new tower antenna on it. The Empire State gets hit by lightning something like 300 times a year--and it doesn't knock the stations off the air, or damage the building. (Except for some holes in the roof, literally.)
Those guys know that a good grounding path can carry the jillion volts and amps right down into the ground, without destroying the goodies alongside it. MOST of the time, anyway. Once in a while--a rare while--they still have to hold up those signs.[g]
Give lightning an express lane to travel in, and it usually will. Leave it to find its own path--and you're likely to take a lot of collateral damage. "Please travel this way" is a very good way to put it!
hellosailor is offline
post #25 of 75 Old 08-22-2008
Seafire327's Avatar
I work for a radio station in Boston and in my time there (4+ years) we've never had a lightning strike knock us off the air. Now I know there is heavy duty grounding since the antenna is on top of the Prutential Tower, along with a lot of other stuff, but I'm not sure of the system in place. When our chief engineer gets back next week I'm going to rack his brain...
And one other interesting thing... Right outside my studio window is the 80 foot tower used to transmit our signal to the Pru and in al this wild weather we've had over the past 2 months, no hit. Not a good feeling sitting almost under the thing though....
'70 Columbia C26 Mk II - "Klydo"
Boston, Ma
Seafire327 is offline
post #26 of 75 Old 08-22-2008
arbarnhart's Avatar
The one I read referred to terrestrial insurance data with the bit about the farm tractors being hit far more (like orders of magnitude) than random chance would explain. But as someone pointed out to me earlier in this thread, I was a believer in a myth myself - tires don't insulate cars and trucks. I still have a hard time believing that a vehicle riding on largely rubber tires is solidly grounded.
That same report referred to a boat study which seemed to indicate that grounding didn't attract more strikes, but the author explained that away. His reasoning was that the owners only said the boat was grounded if it was explicitly wired to ground, but there were keel stepped boats who didn't claim to be grounded and pretty much any boat with an inboard and mast mounted electroics is grounded. EDIT - By "grounded" in in this context I mean providing a path to the ground, whether it is a proper one that attempts to avoid electronics or through the electronics burning up wires and jumping switches.
-Andy
Newport 17 - "Kohanna"
At sea Darwin's hypotheses is the final arbiter of right of way.
arbarnhart is offline
post #27 of 75 Old 08-22-2008
Andy-
A vehicle sitting on four tires is grounded, but nowhere near as well as a tractor or combine with metal bits dug into the ground. Whether a car is grounded or not has little effect on its ability to protect its passengers, since most cars have enough metal surrounding the passenger compartment to act as a rough faraday cage, preventing the lightning from injuring the passengers.
IMHO, the main reason to install a lightning grounding/bonding system on a boat is to protect the occupants. The main thing a lightning grounding/bonding system will do is help prevent sideflashes inside the boat. Sideflashes are probably the most lethal aspect of a lightning hitting a small fiberglass or wooden sailboat. One of my friend's boats got hit about ten years ago, and she said that the lightning leapt from the mast to the starboard chainplate and apparently exited the boat via the starboard chainplate. If she had been sitting on the starboard settee, it probably would have killed her. Her current boat has a 4' x 2" copper plate bolted/bonded to the hull, which is used as the termination for all the lightning grounding/bonding connections. It has five threaded copper studs that come through the hull that the connections are made to.
I don't have a lightning protection system on my boat. I chose to do so, knowing that the chances of my boat are lower by not having one, but take the risk that if I do get struck, far more damage will occur.
sailingdog is offline
post #28 of 75 Old 08-22-2008
Do the studs simply extend through the hull into the water?
Andy-
GBurton is offline
post #29 of 75 Old 08-22-2008
The studs are part of the copper plate. They were soldered or brazed into the copper plate IIRC. The studs and the plate were tinned as well...
post #30 of 75 Old 08-22-2008
Did she design this system herself.......? Interested because my boat had a copper strip bonding the chainplates together then a #4 copper wire going down to a Dynaplate. I took it off
GBurton is offline
Lightning Strike! Kathy Barron Seamanship Articles 0 04-07-2005 08:00 PM
Lightning Strike! Kathy Barron Gear and Maintenance Articles 0 04-07-2005 08:00 PM
Lightning Strike! Kathy Barron Cruising Articles 0 04-07-2005 08:00 PM
Lightning Examined Kevin Hughes Seamanship Articles 0 05-10-2004 08:00 PM
Lightning Protection 101 Sue & Larry Seamanship Articles 0 11-22-1999 07:00 PM
