Exhaust smoke - SailNet Community
Blogs
Old 07-28-2008
winethief is on a distinguished road
Exhaust smoke
I own a Westerbeke 46 with about 3500 hours on it. I was told that the last owner had the engine rebuilt. However, it appears I am getting more exhaust smoke even after the engine has warmed up.
When the engine was surveyed 4 1/2 years ago the compression was great in all cylinders. I know diesel throws some smoke but doesn't it subside after it warms up?
Thanks,
Winethief
Old 07-28-2008
dell30rb is on a distinguished road
they smoke. It shouldn't be thick though
Old 07-28-2008
SteveInMD is on a distinguished road
I assume you are talking about more gray smoke all of the time. Black smoke would be something entirely different.
If you are starting to notice more smoke you may need to adjust your valves, and you may need to have your injectors rebuilt. Neither one of these items is a huge deal. Start with the valves and see if that helps. If you are comfortable with tools you can get a book on marine diesel motors and do the valves your self. You can also pull the injectors and have them sent away to be rebuilt. On my engine the valves should be adjusted every 300 hrs or so. Injectors rebuilt every 900.
white smoke in exhaust SeaSteward Gear & Maintenance 13 04-17-2008 11:26 AM
Diesel exhaust smoke brak Gear & Maintenance 3 10-16-2007 01:43 PM
The Magic Of Sailing USCGRET1990 Off Topic 21 10-12-2007 12:49 PM
Diesel Exhaust Systems Sue & Larry Gear and Maintenance Articles 0 11-07-2001 08:00 PM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 07:55 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
