Old 07-29-2008
surftom's Avatar
surftom is on a distinguished road
Battery question
I just received the new charger (xantrex xc3012) for my batteries
info here: Xantrex XC3012 12V Battery Charger, 30A
I have 2 genereic deep cycle lead acid batteries that came with the boat - (about 100AH each).
We have some new AGM computer UPS power supply batteries at work that I can get (legally!) for free! - similar to these: UB12750H [485105] : Total Trailer, Parts and Services
My question is... Is it worth replacing the 2 batteries i have with (up to 3 or 4) of the AGM batteries. My thought was to have a single battery for the starter and 2 or 3 in parallel for the house bank if i swapped them out.
Have at it!
Tom
Old 07-29-2008
johnshasteen's Avatar
johnshasteen is on a distinguished road
What size boat, how many toys on it, how do you sail? If you have a boat that stays on dock power in a slip and you day sail, then what you've got is fine, if you have lots of eletronics and you cruise (and you've got refrigeration, stereo, fans, electric head, etc.), then look at changing what you've got.
Paloma sits in a slip hooked up to shorepower, and when we sail, it's ocassionally in the bay, but mostly offshore, and fairly short trips of 150 to 650 miles, I have two West Marine dual purpose flooded batteries and they do just fine. I changed from four batteries (two big deep cycle house and two starters) on two battery chargers and running through two battery switches - realized it was overkill for what I do and when the four batteries needed replacement a couple of years ago, I made the change.
s/v Paloma, Bristol 29.9, #141
Slipped in Bahia Marina, easy access to Corpus Christi Bay and the Gulf of Mexico.
Old 07-29-2008
surftom's Avatar
Pretty similar situation here.. 26' mostly daysail - occasional "week away"
Lots of toys! - GPS/Sonar, Satellite radio, laptop, VHF and one of those "electronic coolers" (Peltier device I think) - mostly only on the slip though. I can be pretty conservative with power when out and can plug in on the slip when home.
It's more along the lines of not wanting to give up a free deal! - also, from a potential problem perspective, the AGMs seem like an "easier" battery - no spills, gassing etc
Tom
Old 07-29-2008
camaraderie's Avatar
moderate?
Why not? New AGM's with more storage capacity for free vs. keeping older flooded cells. sounds like a no brainer. Would suggest you use the AGM's as ONE bank and keep one of the flooded for starting duty since your Xantrex can handle multiple types and charge them independently.
Installing a Automatic Battery Selector Switch artbyjody Gear & Maintenance 24 07-08-2008 07:07 PM
Battery question Northbeach Gear & Maintenance 9 01-10-2008 10:55 PM
Battery Bank Design Kevin Jeffrey Gear and Maintenance Articles 0 05-12-2003 08:00 PM
Installing a New Battery Bank Sue & Larry Gear and Maintenance Articles 0 09-26-2002 08:00 PM
Boat Battery Power East Penn Manufr. Gear and Maintenance Articles 0 01-18-1999 07:00 PM
