07-29-2008
Termite Fodder
Originally Posted by arf145
Since you are looking for a solution that doesn't involve unstepping the mast, I think this is going to involve drilling a hole. If you know which side the wire/conduit is supposed to be running down, carefully drill a small hole there, fish a stiff wire with a hook into the hole, try to catch the offender, then secure the wire to the outside of the mast. Won't be particularly pretty, and may not even be recommended. I'm just throwing this out there, in case you're desperate (you are saying "Argh" after all).
Of course, you wouldn't want to secure the wire where it would get in the way of an internal halyard or anything. Now I'll step back and let others tell you what a bad idea this is
Actually, the only thing wrong with your idea is that the single low-pitched banging sound of a loose conduit or wire will be replaced by two higher-pitched banging noises from above and below the fix..
Mast wiring really should be secured the entire way up - unless you're lazy like me and you hang it from the masthead down the center of the mast with internal halyards between it and the mast wall as cushioning... but that's a topic for an entire previous thread.
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
