That Smell! - Page 2 - SailNet Community
post #11 of 23 Old 07-30-2008
The best sanitation hose is probably Sealand's ODORsafe hose, but it is pretty expensive and fairly stiff and hard to work with as a result. It is far more resistant to odor permeation than other hose.
The research I just did into this suggests that Trident 101 is better. I'll see if I can find where I read that. Back in a few . . .
Edit: Of course now I can't find it. This link says, I think, that OdorSafe is better. It also says that there's a much cheaper equivalent. Re: Ping Peggy re: sanitation hoses
mwrohde is offline
post #12 of 23 Old 07-30-2008
Best Looking MALE Mod
Cruisingdad's Avatar
Originally Posted by SteveInMD View Post
I think there are two issues here. The original post said that everyone on deck knows you have used the head. This happens because gas is forced out of the above deck tank vent as the liquid enters the tank. You can install a filter in the vent line to capture the odor. Search the Internet for a Sealand SaniGard Holding Tank Vent Filter.
The rotten egg smell coming from the head itself during the first few flushes is likely from the intake seawater. When you don't use the head for a while the microorganisms in the seawater breakdown anaerobically in the intake hose which creates the sulfur smell. When you flush you pull the stinky water in the bowl. There are few solutions. Add a Y valve (and a check valve) so you can pull water from you tanks for flushing. You only need to use the fresh water for the last flush or two before you leave the boat. Add the valve as close to the seawater intake as you can. Or you can by a small inline treatment item that adds a chemical to the intake water as water flows past it. Or you can open a hatch when you arrive at the boat and flush the head a few times. As long as you use the head twice a day or there shouldn't be time for the anaerobic decay to to happen.
Right on target response from you again, Steve.
However, I will warn you that once you get a colony building up in the intake (NOTE: INTAKE - NOT WASTE) line that it takes almost forever to get rid of it.
I have the exact same head you have (in fact, two) and just rebuilt last week. First of all, you can stop the wter coming around the pump handle by putting a 1/4 turn on the plastic nut. Pump it. If still leaking, do again. It has a rubber washer in there with packing materieal on top of it. The nut is made to be adjusted over time to address the wear of the packing material. That should stop your leaking around the handle.
Second, to get rid of the intake line smell, you have to constantly use the head. We did not find, even as liveaboards and using all day, that it totally went away once a good colony was in there. We tried inline deoderizers, but they were expensive and their success marginal. By using it a lot, you are keeping a large buildup/decay from growing in there - but it still will, so that will not solve the problem either. What I have done is very different. I bought a groco strainer and break up a HOUSEHOLD Cl tank drop-in treatment (Made by Clorox, but there are others) into the strainer inline. I also drop a Teflon Blue Tank Treatment in there to help coat the rubber gaskets. THis should not hurt your hoses, but will cause some premature deterioration on the rubber and plastic gaskets/pieces inside the head. Mine has been in for about two years I guess. We used it for about a year before that. So, plan on a rebuild every 2-3 years if you use this system. However, there is NO (read NO) smell in our head and it actually is VERY pleasant.
Third, you mentioned an enzyme treatment. THose require your tank to be Cl free and chemical free or you deteriorate the enzymes or bacteria and they become ineffetive. If you are going to set up the Cl system I talked about, you will not be able to use those. But, those are really expensive and only work marginally (especially in colder climates). Best bet is a basic chemical (and environmentally safe) treatment. It is also the cheapest. It will help break down the paper and waste in your tank, along with some deoderizing to help mask the smell. The CL will also helo, should you go that route, to keep any bacteria growth down to a minimum.
After that, just constant pumpouts (with several flushes of clean water) will take care of your problems... at least to the point that it is tolerable for you and those around you. You will also finde your boat smells a LOT better down below.
Hope that helps,
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #13 of 23 Old 07-30-2008
The quick and dirty for moving that hose where you want it to go is hot water. The hotter, the better.
Cap'n Gary
Gary1 is offline
post #14 of 23 Old 07-30-2008
poopdeckpappy's Avatar
I would start by cleaning the head of all dead sea critters that are under the bowl lip, rebuild head pump ( or replace head ) make sure tank vent is clear ( enlarging it also wouldn't hurt ) and use KO after every pump out.
If that don't stop it, check lines for permiation and replace as needed, then clean, scrub and flush the bilge
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #15 of 23 Old 07-30-2008
I'd rather be sailing
labatt's Avatar
You might also want to use a good holding tank enzyme. Peggy Hall recommends "KO", which is what we use (being on a lake, we have to always use the holding tank). It seems to work real well with minimizing the smell from the tank based bacteria. It's available at West or a variety of other places.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
labatt is offline
post #16 of 23 Old 07-30-2008
cap'n chronic
cnc33voodoo's Avatar
i poured 6 litres of bleach into the holding tank,filled it with water and let it sit, back flushed the vent with the water hose and pumped out the following weekend. i have not had a foul smell since.
works great on stinky bilges too.
c&c 33 tall rig
cnc33voodoo is offline
post #17 of 23 Old 07-30-2008
Household chemicals such as bleach are problem the worst thing you can pour in any , fresh,gray or blackwater system
1974 Ranger 33
post #18 of 23 Old 07-30-2008
Not if you're trying to shock treat the system and clean it out. Using them on a regular basis isn't such a good idea, but using it once a year or so to commission or decommission the boat for the season, it isn't such a problem.
sailingdog is offline
post #19 of 23 Old 07-30-2008
True true, I did that on our freshwater system right after buying the boat a little over a year ago
1974 Ranger 33
post #20 of 23 Old 07-30-2008
The best thing I have used is "Aqua Kem" available at Camping World. It is very concentrated and takes only a little. Absolutely no oder. I tried at least 3 different types from West Marine and none even come close. Also it is less $$ than anything I tried from W.Marine.
Neicy is offline
Mildew Smell! Windermere Gear & Maintenance 22 09-25-2007 07:06 PM
Smell of Success - ABC News NewsReader News Feeds 0 03-14-2007 03:15 PM
head water intake smell JHodor Gear & Maintenance 2 10-04-2006 10:41 AM
That Diesel Smell Mark Matthews Gear and Maintenance Articles 0 08-27-2001 08:00 PM
