07-31-2008
Bene-
It really depends...
It would help a lot if you said what model Lofrans windlass it was. Is it a hydraulic or electric windlass.
If it is an electric windlass, the spinning noise is likely the motor. Chances are good that one of the buttons is stuck—either raising or lowering the chain—and the gearing inside the windlass broke because of it. When you power up most windlasses, they don't make noise unless they're actually being used.
If it is a hydraulic windlass, the spinning noise could be a pressure pump for the hydraulic cylinder. Hydraulic windlasses are a bit more uncommon.
I'd also highly recommend you read the POST in my signature.
