07-31-2008
Interstate makes a pretty decent battery. The sizzling noise is probably the electrolyte boiling, which is pretty much normal when you're doing an equalization charge cycle. 12.62 VDC is pretty much 100% charge or so for a 12 VDC battery.
You need to get a load tester and test the battery. Or, alternatively, you can get a hydrometer and check each cell in the battery to see what the specific gravity is. Ideally, you should do both.
