fresh water system stopped working after fill-up - Page 2 - SailNet Community
post #11 of 27 Old 08-01-2008
Moderator
JohnRPollard's Avatar
Originally Posted by HoneyDoII View Post
John,
I read it slightly different. I made the assumption some amount of time passed between when he viewed the boat and then bought it before he sailed it away. Given that time, the PO could have turned off valves as part of his standard exiting proceedure.
My other thought was that the initial test could have used up any water remaining in the line prior to the cut off valves.
Just ideas...
You're probably right about that....
JohnRPollard is offline
post #12 of 27 Old 08-01-2008
trantor12020's Avatar
check the filter.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #13 of 27 Old 08-01-2008
Pull the lines from both sides of the pump and run the pump. See if there is suction on the inlet side of the pump.
I'm still having wierd pressure issues with my system. I found high backpressure at the outlet side of the pump once. Fixed the problem and it hasn't come back. But I'm occasionally getting warm water out of the cold water faucets. I think I need a stronger check valve on the hot water tank.
xort is offline
post #14 of 27 Old 08-01-2008
Wannabe Sailing Bum
Vitesse473's Avatar
My 473 has three separate tanks, and therefore 3 separate valve handles near the water pump. You mentioned the boat is new to you, so I suspected that your haven't located those valves yet. Mine ('02 Bene) are small finger valves each about the size of a silver dollar. They are underneath one of my settee cushions just forward of the galley (right next to the water pump).
Additionally, I see nooooo reason why over filling would do any damage to the tank (unless you were using a fire hydrant).
Vitesse473 is offline
post #15 of 27 Old 08-01-2008
T37Chef's Avatar
Originally Posted by Bene505 View Post
Now it doesn't work, only sputters a small bit of water out of the faucets. Any ideas?
How long did it sputter?
I ask because if I have run the tanks down, the water heater as well, it takes some time for the pump to pump water into the water heater and build pressure in the system, and will get the sputtering as you describe until the system is primed.
Maybe all you need to do it give the pump some time???
Shawn
T37Chef is offline
post #16 of 27 Old 08-01-2008
poopdeckpappy's Avatar
I kinda agree with the Chef, you should open all faucets especially the hot and let it cycle, then work your way from the farthest fixture and kill the water,leaving the galley hot side for last. depending on how big your HWH is, it may take a couple minutes to fully pressurize
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #17 of 27 Old 08-02-2008 Thread Starter
Glad I found Sailnet
Bene505's Avatar
Thanks for the suggestions, I'll look at doing the simpler ones in the morning.
Just so we have the symptoms right: the system worked, I filled the tanks, the system stopped working. All in the span of and hour -- it took that long to fill the tanks from the dock hose. Only after it stopped working did I mess about with closing/opening valves to individual tanks.
Oh, and the backup pump is an identical electrical pump. You throw 2 "Y" valves (inlet, outlet) and a switch (power the other one) to operate the alternate pump instead. I didn't mess about with that until after there was a problem. The filter going into this pump/valve arrangement is pretty clean. (The pumps are immediately under the dinette seat, well above the tanks.) Opening all the faucets didn't work.
I'm thinking it's the valves, as you suggest, so I'll look to make sure they are open. (Maybe what I think is open is really closed.) It sure seems like that's the issue, even though no change was made after filling. Then perhaps it's not priming or something. So I'll try the "open inlet port" second, then the "disconnect outlet side of pump" method third.
One last thing to be 100% clear on the symptoms. When filling, I couldn't get one of the 4 filler ports to open. [I even tried putting a piece of dry ice on the screw-cap (to shrink it) but that didn't work. Having learned from mistakes before, that nothing on a boat should be forced too hard lest it break.] So really one of the tanks was not filled.
Bene505 is offline
post #18 of 27 Old 08-02-2008
T37Chef's Avatar
I usually fill my tanks from the inspection port on the tank, try to fill that other (which you could not get the deck plate off to fill) tank this way, run the pumps again and see what happens, it may take several minutes?
Does the pump sound different then when it was working properly?
Shawn
T37Chef is offline
post #19 of 27 Old 08-02-2008
I'd rather be sailing
labatt's Avatar
Just make sure you check those screens on the faucets... like I said, similar symptoms to us, we spent a long time investigating and pulling things apart, turned out to be crud on that screw on cap on the faucets - all of them. The water sputtered, came out really slow, etc.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
labatt is offline
post #20 of 27 Old 08-08-2008
Well, either Bene ended up stuck in his bilge, or he fixed his problem and does not need us any longer.
tommyt is offline
Potable Water tdw Provisioning 31 08-11-2007 07:30 AM
Who is Killing Our Water Access lowryjim General Discussion (sailing related) 14 07-18-2007 06:16 PM
Checking Water Quality & Cleaning Headliner dougshipl Gear & Maintenance 6 05-23-2007 02:17 AM
Fresh water system maureena5 Gear & Maintenance 6 03-07-2007 06:34 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 05:59 PM
