fresh water system stopped working after fill-up - Page 3 - SailNet Community
post #21 of 27 Old 08-08-2008
Actually, he opened the wrong seacocks and scuttled the boat.
Originally Posted by tommyt View Post
Well, either Bene ended up stuck in his bilge, or he fixed his problem and does not need us any longer.
sailingdog is offline
post #22 of 27 Old 08-08-2008
When you turn off the faucet, does the water pump stop, or continue to run? Do you have a hot water bypass valve? If the pump continues to run, and you do have such a valve, then water is being diverted back to the tank, and just shutting the valve should solve your problem If you don't have a bypass valve, NEVER MIND.
Marc
gershel is offline
post #23 of 27 Old 08-08-2008
Moderator
JohnRPollard's Avatar
I feel used...
JohnRPollard is offline
post #24 of 27 Old 08-08-2008 Thread Starter
Glad I found Sailnet
Bene505's Avatar
Thanks everyone for the great advice. I've been fulfilling family (cruising) expectations and haven't had a good chance to reply until now.
I tried disconnecting the outlet hose from the pump and varying the tank selector. I found that there is an air leak in one of the four inlet lines. My previous combinations of tank choices either did not isolate away from that tank or didn't run for long enough to get the air lock out (or the air lock -- as Speciald mentioned -- just couldn't get fixed without letting the pump run with no outlet pressure).
When I disconnected the outlet hose and *watched it* carefully while switching tanks and waiting, the problem suddenly revealed itself. -- It was key to disconnect the outlet hose.
Sure enough, I just checked it now. A normally operating system started to sputter within 20 seconds after switching to the air-leaky tank (at least I assume that's the problem for now, since that tank was filled recently).
Not sure why the timing of the air-leak problem showed up after I filled all the tanks. It might be a coincidence, but I know I didn't switch anything or change anything, just filled the tanks.
In any case, thanks again for the great advice. Next steps is to optimize everything by finding the air leak, applying Labatt's advice and check the screens on the faucets, and trying T37Chief's method of filling via inspection port.
Thanks again, and how can I pay back this community for the great help?!?
Bene505 is offline
post #25 of 27 Old 08-08-2008
trantor12020's Avatar
for a start you could send a US$10 check to a chairty of your choice each time the community help answer or resolve your query. I'm sure everyone is glad to help.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #26 of 27 Old 08-11-2008
I'd rather be sailing
labatt's Avatar
Glad to hear it worked out, and thanks for reporting back. It's always interesting to find out what the problem turned out to be...
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
labatt is offline
post #27 of 27 Old 08-11-2008
T37Chef's Avatar
Thumbs up We accept cash
I would be happy to send you a self addressed envelope in which you could make a deposit to the New Boat fund
Glad to hear you found out the problem, now onto the next one?
Shawn
T37Chef is offline
Potable Water tdw Provisioning 31 08-11-2007 07:30 AM
Who is Killing Our Water Access lowryjim General Discussion (sailing related) 14 07-18-2007 06:16 PM
Checking Water Quality & Cleaning Headliner dougshipl Gear & Maintenance 6 05-23-2007 02:17 AM
Fresh water system maureena5 Gear & Maintenance 6 03-07-2007 06:34 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 05:59 PM
