08-03-2008
Delo is good stuff. The other good choice is Rotella, if you want to stick with conventional oil.
I'm running my Phasor generator (Kubota diesel) on Valvoline full synthetic, and have had very good luck with it. If you decide to switch to a synthetic, it's worthwhile to do one oil change with it, and follow it up in short order with a second one--say in ten hours or after one weekend's use. That will get the last of the conventional oil out of the system.
Cap'n Gary To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
