08-03-2008
A couple of thoughts...
I'd go with the aluminum framed windows, since they're probably going to be easier to maintain in the future PROVIDED you install them properly. If you go with the aluminum framed windows, make sure that you use TefGel or Lanocote on the fasteners to help prevent galvanic corrosion problems.
As for your replacing the teak plywood with seaboard, I'd say that is probably a bad idea. If the teak plywood was installed as a structural stiffener, replacing it with Seaboard, which IIRC, isn't meant for use as a structural material, is a really bad idea. If you want to make the interior white and really low maintenance... install marine plywood that has been epoxy impregnated and then laminate white formica or other surface laminate to the plywood. This will give you the same structural strength of plywood, with the low maintenance finish of a plastic laminate.
