08-04-2008
Look for burrs on the mounting posts for the pawls, and make sure there isn't a huge amount of grease on the drum side, too. If you're primarily racing, I'd probably use oil on everything but the center bearings, and just make that part of the pre-race routine--take the drums off, put a few drops of oil here and there.
Lewmar's grease is no better or worse than most when it comes to caking up. White lithium grease is the worst.
Cap'n Gary To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
