@#$%^ Blisters - SailNet Community
post #1 of 10 Old 08-04-2008 Thread Starter
@#$%^ Blisters
My Pearson 32 has blisters. So, I researched hull blisters. I've found some articles that describe peeling and redoing the bottom (cost prohibitive), others recommend drilling out the blisters and put an epoxy plug in, other articles say the epoxy plug will fall out, still others say blisters are cosmetic and not a problem, leave them alone and don't destroy your hull.
In summary, I've gotten answers. All kinds of answers, so many, I'm not sure what to do. So, I'm asking the opinion of those who have dealt with hull blisters, all kinds of hull blisters.
I've read the blisters contain some form of acid and continue to eat the hull.
Do you drill and plug them, or leave them alone?
BudRICKETT is offline
post #2 of 10 Old 08-04-2008
Check out the link below. I just happened to be looking at this site this morning and it has some very good information. You might also want to look at the article on Moisture Meters - also very good.
Hull Blisters on Boats and Yachts - by David Pascoe, Marine Surveyor
BigAssHam is offline
post #3 of 10 Old 08-04-2008
Barkeep - Sailor's Pub
craigtoo's Avatar
Send a message via AIM to craigtoo Send a message via Yahoo to craigtoo Send a message via Skype™ to craigtoo
There is some good info already here in the forums...
Blister 1
Blister 2
Blister 3
http://www.sailnet.com/forums/buying...light=Blisters
barrier coat
Blistering
search "Blisters"....
By the way... the more information you provide... where the boat is... Salt/Fresh...Hot/Cold....how big the blisters are...has the bottom been redone in the past? Where they are on the boat? etc. etc. etc. Pics would also be good. Your question is pretty general... but we want to help!
-C2
1987 Sabre 34 "Saoirse"
Meet me at the
I love
craigtoo is offline
post #4 of 10 Old 08-04-2008
ASA and PSIA Instructor
Blisters can indicate a wide variety of underlying problems, stretching from the the trivially cosmetic to the catastrophically fatal. you need to figure out where your boat fits on the scale, probably best involving the advice of an experienced surveyor. The more blisters there are, the deeper they are, and if the hull stays wet after a few days out of the water (not to the eyes, but when tested), especially if it is a cored hull, the mor elikely the blisters represent real trouble.
sailingfool is offline
post #5 of 10 Old 08-04-2008
I've seen Carver's with blisters above the water line.
funsailthekeys is offline
post #6 of 10 Old 08-04-2008
moderate?
camaraderie's Avatar
Read this...
This will give you all the info you will need.
http://www.zimmermanmarine.com/docs/blisters%201.pdf
camaraderie is offline
post #7 of 10 Old 08-04-2008
buckeyesailor's Avatar
Most informative link BigAss......thanks
Poverty motivates me in ways prosperity never could.
(stolen from Eddie Jones)
buckeyesailor is offline
post #8 of 10 Old 08-04-2008
T37Chef's Avatar
See this thread, I don't feel like posting it again...Bottom Repairs
Maybe its time for a sub forum of a sub forum of a sub forum about BLISTERS? Okay maybe extreme, maybe just it s own forum?
Wait...how about Blisternet.com????
Shawn
T37Chef is online now
post #9 of 10 Old 08-04-2008
moderate?
Buckeye...note that pascoe is not supported by the research quoted in the zimmerman article...and his views are not supported by most of the marine industry. This has been a prior thread issue recently. Anyone with blisters should read all the links above before making up their mind what to do.
post #10 of 10 Old 08-05-2008
Handsome devil
Stillraining's Avatar
My hull has blisters and they are in the CSM...under that is translucent green very healthy woven roving...Im a lazy sailor/boat owner ...Im just waiting for all the CSM to hit the sea floor...if it all fell off at once that would make my day.
If yours is like mine I wouldn't worrie about it...it accounts for little structural integrity ( it was only there to hide print through ) and it will add some weight to your boat due to being waterlogged...if your not a racer weight is a good thing...
OK... thease may all be tong in check answers but its how I feel...take it or leave it...no expert but Ive owned boats for 42 years.. none have sunk yet..just my 2 cents..
Stillraining is offline
Theory on cause of Fiberglass Hull Blisters travistowle Gear & Maintenance 119 10-31-2011 08:59 AM
The Dreaded Blisters winchwench Sailboat Design and Construction 19 08-08-2008 02:12 PM
The question of Blisters yet again? mvsunstar Boat Review and Purchase Forum 23 02-03-2007 10:29 AM
400 half inch Osmotic Blisters davidsmcse Gear & Maintenance 3 11-22-2002 07:19 AM
Hull Blisters Don Casey Gear and Maintenance Articles 0 09-11-2000 08:00 PM
