Leaking Toe Rail - SailNet Community
Blogs
Old 07-16-2002
CMDuer is on a distinguished road
Leaking Toe Rail
I have a 1968 Morgan 30 & I am getting a few leaks coming down the inside of the hull, from under the toe rail area. Any ideas on the cause or how to fix it?
Thanks in advance.
Old 07-16-2002
Jeff_H's Avatar
Super Moderator
Leaking Toe Rail
There are a number of possible sources of leaks in the area of the toerail. Water can get in under the toerail itself and then bleed down through the fastenings for the rail itself. This is also the area of the hull deck joint and water can get in through the hull deck joint of its fastenings. Lastly there are bolts for sail tracks and other hardware in this area. It is also the low point of the underside of the cabin and so water can migrate there from other parts of the boat.
The big cure is to remove and rebed the toe rail which is a big job but which should last another 34 years. Plan ''b'' is to rake out the joint and caulk with Boatlife from the exterior which, assuming the leak is from the toe rail, should last a couple years depending in the quality of the job and the climate.
Old 07-17-2002
Leaking Toe Rail
Jeff, Thanks for your insight. Once we have some good dry weather, I will get into and see what I find. Appreciate your help.
Toe Rail Issues sjacovino Gear & Maintenance 9 11-25-2004 10:08 AM
Leaking hull deck joint sailnaway Gear & Maintenance 0 10-12-2004 08:53 AM
Catalina Stern Rail BillG501 Gear & Maintenance 4 01-03-2004 02:29 AM
leaking gas tanks LarryLevine Gear & Maintenance 3 04-28-2003 11:37 AM
Toe Rail for a Ranger 28 demcshan Gear & Maintenance 0 05-27-2001 10:48 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
