Undersized Genoa - SailNet Community
Blogs
Old 08-05-2008
dgr dgr is offline
dgr is on a distinguished road
Undersized Genoa
I found a Genoa that measures:
150% Geona 4.5 oz.
Luff 29'
Leach 29'
foot 17'
sailrite lists a Genoa for my boat as:
Luff 32.17ft (9805mm)
Foot 19.42ft (5919mm)
Leech 30.83ft (9396mm)
Obviously that sail won't be 150% for my boat. I'm wondering if I could use this Genoa on my boat? What are the downsides? How plug and play would this be?
Thank you for your time.
Old 08-05-2008
btrayfors will become famous soon enough btrayfors will become famous soon enough
Sure you can use it. A 150% genoa is a bit large for normal sailing needs, anyway. Maybe you can give it a try before you buy?
Re: plug and play, should be just that!
Bill
Old 08-05-2008
121Guy is on a distinguished road
Sail Choices
Hi,
This is an interesting question so I thought I would try to help. The comparison and suggestions should help you make a wise decision. If not, ask more questions!!
First I would take a piece of graph paper and a ruler. I would overlay both sail dimensions using a scale of 1 box equaling one foot.
You will quickly find that the Sailrite dimensions will produce a longer leading edge (luff) and a shorter trailing edge (leech) than the one you are considering. The Sailrite dimensions will give you a high clewed sail, easy to see under but not so good to weather. You should notice the other sail will have a lower clew.
What kind of boat is this? Are you racing or cruising? Do you sail in a heavy air area or a light area? Are both sails dacron cross cut and do they have the same cloth weight?
If the Sailrite dimensions are right for the boat and you do indeed want a large headsail...you will have to measure out the LP on the graph paper as compared to the J measurement of your boat (front of mast to headstay at deck level) to determine the LP percentage of that sail. I'm guessaing it will come out about 130 or 140%.....then is your desire to use it on a furler? Is the luff tape size right?
all for now
Old 08-05-2008
Just make sure that the luff will fit your boat in terms of attachment method. If you use hanks, it shouldn't be a problem, but if it is supposed to fit on a furler... you'll need to make sure the boltrope on the luff is the right size.
Old 08-05-2008
NOLAsailing's Avatar
NOLAsailing is on a distinguished road
There's more to sails than just white triangles. Often, close is not good enough. If you feel that used sails are a way you want to go, then I would suggest purchasing, if at all possible, sails from the same model boat.
-Jason
Old 08-05-2008
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
I agree with NOLAsailing. Those 3 dimensions doesn't mean you'll be able to get the same shape out of it as your current sail. Draft location will be a factor, if you can try before you buy, then that would be perfect. Or buy with the intent that you can return it same day or next day if you don't like it.
Old 08-05-2008
T34C's Avatar
Thanks Courtney.
T34C has a spectacular aura about T34C has a spectacular aura about T34C has a spectacular aura about
Aaaammm, what kind of boat do you have?
What are the dimensions of the fore triangle?
It's kinda hard to know if the sail will work or not without know a little about the boat you want to put it on. I don't think I would trust a sail purchase to the size recommendations from Sailrite. Dig a little deeper.
Maeven
Tartan 34C Yawl #282
Anything-sailing.com
Moderator
Old 08-06-2008
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
As for plug and play, the other posters have covered most of this. Do you have a roller furler or do you use hank on jibs? If you have a furler then the luff tape size makes a big difference.
More info would help the inquiring minds that want to know.
Old 08-06-2008
dgr dgr is offline
Everyone, thank you for the responses and for asking questions of me so that I can get my question of you answered. Since I don't know what I don't know, this is very helpful.
My boat is a columbia 28. The CYOA lists the IJPE as 31.80 12.00 26.70 11.30
I use hanks. This is just a cruiser. I apparently sail in a windy area (SF Bay)but have only had the pleasure of a brisk breeze once since I purchased the boat this summer.
My sailing experience is very limited. My Jib is long in the tooth and as I just spent 2000 on my standing rigging and have 20 other projects on this boat but only one boat buck bucket, I would like to hold off on purchasing new sails for a year so thought I would look into used sails.
T34C, great point! Can you think of a better place than here to start digging?
Old 08-06-2008
camaraderie's Avatar
moderate?
Just google used sails...there are a number of places to choose from that may have a better fit.
Example:
Sail Search Results
1 match found. Go back. New search.
ID Tag Type Luff Leech Foot LP Condition Price
G1908-4B jib 32'8" 31'8" 19'8" 18'4" GOOD $525
dacron, 7 oz., miter cut, double stitching, luff wire, leech line, numbers, some hardware corrosion, #3 hanks, 299 sq. ft., a few stains
Contact Second Wind Sails to Order Your Sail
Hours: 9:00 A.M. to 5:00 P.M. EST/EDT, Monday - Friday
U.S. and Canada, Toll Free: 1-(800) 273-8398
South Florida: (954) 767-8885
Fax: (954) 523-7258
Email: info@secondwindsails.com
main sail from genoa sailbot Gear & Maintenance 16 04-08-2008 01:20 PM
Cutting down a new genoa ian555 Gear & Maintenance 2 01-06-2008 04:22 AM
What is a Genoa? Kacper General Discussion (sailing related) 45 04-05-2007 04:23 PM
upwind Genoa trimming - lighter airs mikehoyt Racing 9 11-25-2004 04:32 AM
Adjustible Genoa Leads, Track & Teflon rick gleason Gear & Maintenance 5 11-28-2002 09:00 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
