08-06-2008
Last Grumpy Old Sailor
Originally Posted by Mary51
Besides it's leaking from several different places. . .
I was almost going to suggest getting all the oil out (trickier than you might think) so you could seal up the leak, but it sounds like what you're describing is the entire weld failing? If so: I'm afraid you're going to have to have the engine pulled and the oil pan replaced.
It's not an "oil drip pan" or a "drip tray," it's an oil pan, period. Even when the engine's running a goodly portion of the engine's oil is in that pan. When the engine's stopped, 75-80% of the oil is in there. There's a sump near the bottom, somewhere in that pan, connected to the oil pump, that brings the oil up out of that pan and pumps it throughout the rest of the engine. More accurate to think of it as the "oil reservoir" than a drip pan or tray.
Worst case: If that seam fails catastrophically and dumps your oil in the bilge while your engine is running, your engine will almost certainly be toast before you can possibly shut it down, even if you do have a low oil pressure alarm.
Jim
s/v Abracadabra
1976 Pearson P30
