Glue/Weld Plastic? - Page 2 - SailNet Community
post #11 of 17 Old 08-08-2008
The problem with tapping a new hole is that you generally shouldn't use metal fittings in plastic openings... since the metal will generally expand more than the plastic and lead to stress cracks in the plastic.
GBurton-
You really should start a new thread instead of hijacking this one.
sailingdog is offline
post #12 of 17 Old 08-08-2008
Francophobe
I would actually say that while the metal expansion is part of the problem even if a plastic nipple were used there is a high chance of stress cracks due to the plastic fitting not being designed with sufficient wall thickness to deal with the tensile (hoop) stress it will encounter when a NPT thread (tapered) is screwed in. The reason when the NPT threads are effective at sealing well is due to the taper applying a force radially outward on the female thread. For this to work well in plastic there needs to be a fairly robust wall thickness to not crack. I doubt that the existing plastic has the required thickness.
_________________
"Ventarrón"
Flying Scot # 4964
Golf is an exercise in Scottish pointlessness for people who are no longer able to throw telephone poles at each other.
-Florence King
To get the most from Sailnet, follow the link in
's signature.
TheFrog is offline
post #13 of 17 Old 08-08-2008
True, but it would be worse with a metal fitting. If you used an NPS fitting, the hoop stress would be lower, since it isn't tapered. No need to use a threaded nipple if you're epoxying it in place though.
post #14 of 17 Old 08-08-2008
Francophobe
Spin welding
SD, I agree with you but I am concerned that it would be very difficult to get epoxy to adhere well enough to the Polypro to glue a nipple in place. PP is just too slippery to glue easily.
Another idea. Find a polypropylene nipple, threaded on one end only. Cut off the old nipple, clean the stub of the old nipple and the unthreaded end of the nipple well. Chuck the nipple up in a drill (preferably a drill press, or make sure you have very steady hands and great alignment). Put the drill on high speed and spin weld the new nipple onto the fixture. Forward Technology | Plastic Assembly - Spin Welders
This is really done best with a drill press and the fixture well supported, you spin the nipple while apply light pressure of it against the fixture. When the plastic starts to melt you stop the spinning and maintain pressure until the plastic hardens. It does result in pretty solid bonds.
McMaster (McMaster-Carr) has a decent selection of polypropylene pipe nipples.
Good luck.
_________________
"Ventarrón"
Flying Scot # 4964
-Florence King
's signature.
TheFrog is offline
post #15 of 17 Old 08-08-2008
But you'd have to get the facing part of the body to be fairly flat to get a good spinweld IIRC. I've done a bit of work with spinwelding, mostly HDPE.
Good luck.
post #16 of 17 Old 08-08-2008
poopdeckpappy's Avatar
Almost any plastic can be welded, one of the many tools I had while racing offroad was a plastic welder, I used for many things but mostly cracked fuel tanks or body parts ( not mine, the bikes )
PP can be welded, ( DIY ) the question is it worth investing a little money into the welder ( which isn't that much )
to help you figure out what plastic you have and what's needed to repair
Identify Plastic
and here's the supply house
Urethane Supply Company - Plastic Repair and Plastic Welders
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #17 of 17 Old 08-09-2008 Thread Starter
Thanks Pappy...I'm off the the boat to dismantle the fixture and get a photo...back in a few days.
"Solitude" Caliber 40
Ches Bay
bhcva is offline
Plastic Lumber Cabin Sole jmcpeak Gear & Maintenance 20 03-18-2007 03:21 PM
Plastic Fuel Tank... marinesniper Gear & Maintenance 4 02-14-2007 11:05 AM
Plastic paint for tired looking plastic parts Goodnewsboy Gear & Maintenance 3 01-01-2007 06:15 AM
Plastic Through-Hull Valves and Valve Flanges John Kretschmer Gear and Maintenance Articles 0 05-27-2001 08:00 PM
