08-06-2008
If this is really a nipple, have you considered a brass nipple from a plumbing supply store? if it is part of a molded faucet, is there enough material in the body to cut off the nipple, drill it out, and epoxy in a barbed fitting to connect the supply line? that would be stronger than gluing the nipple, because of the solid part of the faucet around the glue joint.
Don To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
1980 Endeavour 37 sloop, currently in the Mississippi near St Louis To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
