Old 08-06-2008
Solitude37C is on a distinguished road
Westerbeke Starter Problem
When I attempt to start my Westerbeke 33, the starter makes a grinding noise like it does not fully engage the flywheel properly. If I turn the kry off after this grinding occurs, and again turn the key a second time, the starter will engage the flywheel without the grinding noise and start the engine.
Anyone have an idea what might be the problem and what the fix would be?
I really appreciate any thoughts from this forum.
Lawrence Loyd
Tartan 37C Solitude # 393
Old 08-06-2008
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Starting motor drive pinion needs cleaning or alignment. Check your manual for the maintenance specifications.
Old 08-06-2008
canadianseamonkey's Avatar
Caribbean Surveyor
canadianseamonkey is on a distinguished road
Solitude, I had a similar problem and fixed it. I started this thread:
http://www.sailnet.com/forums/gear-m...er-whines.html
Does it sound like the same problem? Mine was a whine not a grind....I removed it as suggested and sprayed a bunch of WD 40 with some white grease on the bendix and now she's like new. There are only 2 bolts...very simple. I have a Lucas starter, odds are you have the same. Let us know.
Ray
Old 08-07-2008
Gary1 is on a distinguished road
Ray--
Do yourself a big favor and yank the starter back out, clean the white lithium grease off and put on some kind of moly-disulfide grease. Lithium grease turns into white concrete in fairly short order, especially when it gets warm. Just a tip.
Cap'n Gary
Old 08-07-2008
Caribbean Surveyor
Gary, you're giving me more work to do? k, I'll get that other grease you're talking about. Thanks for the heads up.
Old 08-07-2008
chucklesR's Avatar
Boshield T-9 is the best stuff I've ever found for a boat, sprays on, never congeals and works anywhere. Better than wd-40 with a much longer life span.
Old 08-08-2008
Thanks everyone for the help! I'm heading to the boat this morning and will see if your suggestions resolve this problem. I really appreciate your responses.
Lawrence Loyd
Tartan 37C #393 Solitude
Old 08-12-2008
Westerbeke Starter
Sorry to report back that I did not have time to check the starter or perform the starter removal and lube of the shaft. I was scraping and sanding the teak, getting it ready for its new coat of finish. Now I know why it cost so much to have the yard do this!! Probably the most labor intensive project I have undertaken on this boat.
I will get back to everyone when I do get to the starter.
Lawrence Loyd
Tartan 37c # 393 Solitude
Old 08-23-2008
Cleaning the cable connections eliminated my problem! Thanks to everyone who suggested a fix! All the teak ( except those troublesome handrails ) has been refinished and I am pleased with the Cetol Natural Teak......
Lawrence Loyd
Solitude
Tartan 37C # 393
Yanmar starter problem... mrhoneydew Gear & Maintenance 10 08-02-2008 07:53 PM
Starter problem? jeb1 Gear & Maintenance 8 07-19-2008 08:24 PM
philosopher's club HoffaLives Off Topic 106 12-15-2007 11:48 AM
Starter Solenoid Install Problem gpd955 Atomic 4 6 03-19-2007 08:54 PM
Starter Problem pehrst Gear & Maintenance 2 08-29-2002 08:34 AM
